1 hour ago, Dievos said:
I also have real results of an EFR7670 on an RB26, it was within my power goals and I felt like giving it a go seeing as the resaleability of EFR turbos is good and later going with an 8374 with the same rear housing would make it a straight fit.
From what I found we really had to restrict how quickly it came on due to knock, results were inconclusive as I saw power loss in the exact same RPM area as my R32 Nismo turbos. I am wanting to see how far I can go with this before jumping ship and going to a larger compressor.
0.92 IWG?
We are currently using a TS 9180 on a stock-block 1JZ with 264 cams. Made 640WHP on 26psi with a few teething issues and a faulty EBC. Power comes on very nicely for a large turbo and sure holds on well up top.
I certainly expect with some development we will reach 700WHP at the same 26psi though that is certainly dangerous territory on an old long block.
  • Like 4
On 2/6/2018 at 5:27 AM, Full-Race Geoff said:
if anyone needs turbos or speed sensors, we have both in stock and happy to match any prices online.  also we have a new Turbo Speed Gauge that is pre-programmed for EFR turbos:
Got the 1.45 A/R turbine housing on the 8374 this week. Compressor surge was getting quite bad in the cold weather even trying to “hold the turbo back”. It will also mean we don’t have to pull boost out in the top end too.
Will will see by how much exhaust pressure drops too.
God it’s big! Borg Warner and their housings the size of small planets! Gonna have to have a look at the exhaust cam cover and see what I can do with it and get the turbine beanie on. Needs a longer water line which will be done on Monday.
Dump pipe had to be trimmed 8 mm.
  • Like 4
What do mean by having to pull boost out? the cost of EMAP outweighing the benefit of greater MAP?
or EGTs getting too high?
PS thats friggin' massive. the 3" outlet looks hilariously small
Edited by burn4005
EGT’s weren’t getting high... we had 360 kpa exhaust pressure.
However, coming on (sub 4000 rpm) it was compressor surging. So if we are “holding it back” early on, why not give it a bigger ass and let it sing up top. Can’t have it either way.
God knows how the 0.92 guys are going. If I had a 0.92 on my engine it would have been a total waste of time.
I'm not following.. why did you have to pull boost out up top previously?
You said:
"It will also mean we don’t have to pull boost out in the top end too"
Can't imagine it's surge related (low mass flow issue), or turbo speed related (compressor hasn't changed)
It was E MAP related. Hitting 360 kpa. Hoping to drop that somewhat.
However, don’t need a pressure sensor to tell how much better the engine breathes compared to the twins. The engine note tells you that!
  • Like 1
  • Haha 1
I am interested to see your impressions with the bigger housing.  It does lose a bit of response, I personally prefer the 1.05 for most RB engines due to the balance of response and turbine efficiency.
To your second point, however, the twin EFR is another level of breathing compared to the single EFR.  when youre at the point of this volume of airflow, I believe the big twins really are the call
Hoping you could throw up a data graph trace showing IMAP vs EMAP?
Might help people visualise how that relationship affects the scavenge and overall engine efficiency.
Guessing the engine has become a bit more vocal with the bigger housing.
 I’ll see what I can dig up.
Haha yes, I'm very very interested in this as well.    The data geek in my is a little sad that there wasn't at attempt to run it up to max rpm with the 1.05 to get a flat out comparison of EMAP, IMAP and power along with spool between the 1.05 and 1.45 but I understand the position of being a tuner and also owner of a car and having your comfort levels etc.
While 360kpa:260kpa  EMAP:IMAP (1.38:1 EMAP:IMAP) is starting to build up a bit I didn't personally think it was over the top, especially when so close to the suggested max compressor speed - but who am I to question when someone is willing to try the big housing out on an engine which is as likely as any to justify the large one?      ESPECIALLY with all the data @Piggaz has set up to be able to record.
How the new housing affects spool, cylinder filling, surge, compressor speed, power etc etc is all very relevant to my interests.  So much science!
Looking forward to seeing how this comes out :)
Edited by Lithium
I keep hearing about these twin EFR results on but yet to see any that really stand out. Have you got some results of RB or 2J 6258/6758/7163 twin setups handy that you can throw up?
Twin 6258’s or 6758’s are still quite a lot of airflow and the 67’s outflow a 9180 (Atleast according to the compressor maps).
Some of us have already done all the comparisons :P
map/tip is the way you should be looking at it as pressure differential across the engine, and its not a text book relationship either, talking 3.15lt engine here on 9180 turbo. Acceleration data in real world is your best indicator if you are running say 1700mB map with optimized ignition and fuel and then on 2850mB map you have double the acceleration, then all the 'theory' of excessive pumping losses on exhaust stroke or egr effects counts for little except maybe on arsebook or some other useless vlogs :)
I agree with Geoff, a 1.05 on the 9180 makes for the best compromise.
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
