5 hours ago, ActionDan said:
Sorry I don't follow? I thought we'd all agreed that -9s were relatively responsive? Or is this a lead in to telling me to go single :D I'm in Vic, not happening.
I'll try Simon, cheers.
I have HKS GTSS (-9). Bloody responsive as hell. I.E I have 20psi by 3900rpm and 23psi (i have head studs) by about 4300rpm. Gained roughly 60 to 70KW in the low- mid range compared to my old -7 setup.....
My exhaust is restricting me up top now :-(
I plan on getting Type R cams sometime next year too...
2 minutes ago, Dose Pipe Sutututu said:
Yep, seen it. Noted the feedback on here that the real world dyno testing wasn't as generous.
I'm on 25psi by similar rpm, also headstuds.
What are you basing that buying decision on?
I want a mild cam, but not lose 25+ KW between the 75km-110km (3-4 ishkrpm zone) I guess my buying decision is based off the dyno results I've seen with those that run Type B, and figuring the Type R has the same lift, with almost stock duration. I can live with a few KW loss in the lower end as the -9 is really responsive anyway.
Fair enough, what gain are you expecting from mid to top end?
1 minute ago, Piggaz said:
Another option is the Mines Shore pro 2 shafts which are 252 @ 10.05. A little more expensive though. Almost another 1 mm of lift though.
I've heard about these before, fit a standard head? No risk of smash smash with that lift?
1 minute ago, Dose Pipe Sutututu said:
I wouldn't say a dash -9 setup is responsive at all... that's just me.
Agreed, not in the way that stockers are. My 33 with standard R34 BB's on it and 18psi was a beast for traffic light grand prix.
My 34 would reel it in and blast past one the speeds climbed though.
They come with new buckets. I *believe* they drop into a factory head but can't confirm.
and even though the -9s hit 23psi or so by 4300rpm.. before that magical RPM.. it makes less torque and less power than a diesel Golf.
I'm making 180 RWKW at 100km/h. I'd say that's about on par with a 4ltr Barra motor :-)
not exactly the same setup as yourself but for reference...I managed to shift full boost (18-20psi) by 400RPM just by playing with cam gears without losing any top end.
I have RB26, -7's, 98RON
I went from 2 degrees advanced on inlet, 4 degrees retard on exhaust......to 6 degrees advanced on inlet, keeping it at 4 degrees retard on exhaust.
  • Like 1
smart move...
Cams will NOT give you response
  • Like 1
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
