I could live with the graph being pointer in the middle if the final position was not lower.
I like the top end pull it has now. I just want it to come on sooner and harder because that's fun to drive.
When I changed the intake cam on the Silvia from 240 to 248 and dialled in the gears, on the dyno, I ended up with better response, and more torque and power everywhere.
Different motor though not sure how relevant that is.
I always appreciate the feedback and discussion but I ask for results becausw of things like the pods vs airbox debate.
I saw first hand the factory box was a restriction well under 400kw despite everyone swearing black and blue it wouldn't be.
Dyno proven, nothing else changed and pods made more power.
Again I'll reiterate that I always appreciate and listen to the advice I receive :)
So I always look for real world test results, not just theory.
Totally unrelated however this is good info for max torque and lag.
Recently, well about 3 months ago I retuned a SR20 with a full TS GTX3071 0.83 setup and it previously had a set of homo BC 264 cams in them. Turbo came on at 4.7k rpm, max torque was about at 6.2k rpm and you could imagine how useless, how shit that would be. Power kept climbing but what for? I had to cut the revs at 8 because still had a hydraulic lifters
I advised the owner  (again) to go smaller duration cams, he kept saying these cams are responsive blah blah blah. Anyhow he obliged and got basic 256 Poncams. All 1.8bar is now in by about 4200rpm, max torque is now at a sensible 5.4k rpm and car shits out a fun 350kW.
#truestory
Like I said earlier. I increased duration and advance in the Silvia and got more of everything. Went from mild to a little less mild duration and lify.
We're not talking going from stock 240 to 272.
I wonder if camtech would make a version with 248 duration and max lift before it needs buckets?
Wonder why type A cams never get much consideration?
To date my smaller 2.7L is producing 20psi on 98ron earlier than 2.8L's on E85 with the same turbos.
Which is something to think about.
I get positive boost from 1,500rpm and starts pulling from 2,500 rpm which is where you want your cams to operate.
My boost plotted againt Paul's and biggest difference is cams and lack of head work on my part.
So yours is the red line?
I'm not sure why the get ignored, I looked at type A also but the R seemed to be pegged for best response.
I'll dig up the graphs we did from the silvia which showed cams effect on boost, torque and power.
Did you go from stock to type A and gain response and midrange?
Here they are. This was a bigger intake cam, 240-248 with a tiny bit more lift, and cam gears being adjusted.
As you can see, more response, more torque and more power everywhere. It starts to cross over right at the top of the rev range, bu I'm shifting by then anyway.
In my head, this is what I expect from Type R cams dialled correctly, am I way off the mark here given that if I did type R I'd be doing exhaust cam as well?
Did the Silvia work better because only the intake had greater duration so there was no/minimal overlap ruining the down low?
 But you've got it all worked out, you have a line drawn on Paul dyno sheet with paintshop, you have your Silvia's result, you want to put cams in it. Now all you need to do it do it and prove everyone wrong
  • Like 1
Haha, so salty :D I love it.
Surely you've gotta see my thought process about really wanting to dig into things after the pods vs airbox bullshit.
How many people swore black and blue airbox wasn't a restriction. Yet oddly my dyno result seems to have just been ignored.
I get the theory regarding too much duration causing excessive overlap and costing power down low, and we've seen that with bigger cams.
What we don't know is how much duration, and at what cam gear settings, that becomes an issue.
Nobody has shown me Type R cams vs stock on a graph yet.
In essence, you're probably right, I may just need to buy them and dyno test like I did with the pods.
I don't mind being wrong, I just like some actual real world data either way, not just theory and people jumping on a viewpoint despite having no personal experience with it, such as the airbox vs pod discussion.
There was a little salt with the silly line drawn on the dyno sheet as a quick search for a genuine dyno sheet show a very different result
soon have a huge order I need to do and it will come in that order
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
    • Well it wasn't as easy as I thought.... and it also wasn't in my original manual which I did end up finding. They discuss the process in the Nismo catalogue though and it requires slight machining. Page 145.  NISMO PARTS CATALOGUE 2020
