Injector loom modified, injectors fitted, splitfire coilpacks fitted & engine loom wiring in progress...5947b1ec03160_enginewiring.thumb.jpg.f8cefb44982d82e0f6b0358dd8aa012e.jpg
Ditched the thermofans as they weren't really keeping temperatures under control, back to engine fan but a bit too close for my liking...
Have purchased GKTech engine fan which supposedly is thinner & more efficient (win-win) - on its way....
Dummy-fit the top intake manifold & Neo engine cover to see how it will all look. So far so good! Couple of hoses on their way from Japan to finish the intake plumbing...
Hopefully finish-off the wiring by next weekend & get the car ready for some intercooler, intake pipe & dump/front exhaust fabrication!
  • Like 1
Loving the progress, making me lean more and more to doing a neo rather than a standard RB25! you had any real difficulties with the wiring so far? or has it all been pretty straight forward?
  • Like 1
Wiring still in progress but a lot trickier than a s1 rb25 motor.
The neo loom has so many plugs for TCS, ABS, Sensors, Headlights, etc so its been slow progress to work out which to keep & which to cut.
So far, Ive worked out that the rb20 ecu grabs ignition voltage near the plug at the airbox and its a matter of wiring this to the brown eccs/ign relay & another pin on the ECU.
Im trying to make sure aircon, power steering, hicas, wipers & all dash switches/sensors work with the Neo so am tracing each wire to each plug and working through it slowly.
The Knock subloom on the r32 is separate and connects into the rb20 engine loom; whereas the Neo knock loom is integrated into the Alternator subloom; still working out best way to connect into the Neo loom.
  • Like 1
Working on all the little-bits to make the car go...
Time to flex!
Nothing beats new parts...replacing the coolant lines.
New clutch slave cylinder with custom hose
Tailshaft shortened, balanced & fitted.
Replaced the 30mm Turbo spacer with a 20mm spacer, much  better fitment now, hopefully the dump/front clear the aircon lines now...
With a 7ltr ASR extended sump, means more oil - bought enough for two changes & gearbox oil to suitoils.thumb.jpg.6e066d3e750d15669343cb30b8c2ae10.jpg
Hopefully next week we will be in a stage to fire-up and see if my wiring has been done right!
  • Like 5
On 7/14/2017 at 5:34 AM, rx-line said:
What compression pistons?
Specifications
Part Number: SC7297, 14028-6
Make: Nissan
Engine(s): RB25DET NEO
Year(s): 1998-2002
Piston Material: 2618 Aluminum
Bore Size: 86.50mm
Compression Ratio: 9.0:1 CR
Connecting Rod Material: 4340 Forged Steel
Connecting Rod Length: 121.50mm
Compression Height: 1.220"
Wiring loom finally sorted and Nistune + flex board soldered in.
Despite AFM plugged in, larger injectors on a stock map and no intake pipe connected, the engine cranked & started!
Car will be towed to fabricator and tuner on Monday, hopefully have a running car this Friday if all goes to plan :)
  • Like 4
Some fantastic work done by Havoc Fabrication, their attention to detail, care and professionalism is above all else. Thanks to their workshop for tackling this mammoth of a job.
  • Custom stainless steel intercooler piping with zero holes cut
  • Custom stainless steel intake pipe from z32 airbox
  • Custom stainless steel dump & front pipe with another cheeky o2 bung for wideband sensor/tuning
A couple of wiring gremlins to sort out last minute but the car is ready for run-in tuning this Monday :D
  • Like 6
    • Bah! I can't see the point in custom number plates at all. I went to the rego office, fished through a box of "premium" plates (the ones that had the "not as tall" option for the front plate) and picked the one that had a 32 in it. That's the limit of the effort and cost I will put into number plates. The only plate that I'd consider paying for would be 2332, but that's not possible here because it already exists from probably 90 years ago, and it would cost a fortune to obtain it, if it were available.
    • After chasing my tail with LS results..... and cheaper than a turbo swap... How confident are you that the dyno is accurate relative to other results? How fast is the car - What MPH does it actually run? Is this similar to what people running this power would expect?
    • Hi mate I am having an identical issue with my 98 R34 GTT. The engie suddenly cuts out under load at about 3-4k, black smoke out exhaust. Almost feels like traction control kicking in. No CEL but still going to check codes later today. Car was sitting in the shed for about 5 months before hand and only idled a few times, took her out with about 1/4 tank, filled up and thats when the issues started happening.  Threw on a spare set of coils/harness and checked plugs which was no help. Recently had fuel pump/filter changed so surely thats not the issue unless condensation in fuel, I just havent had the time to drain it It's running a hi flow turbo, bosch 1000cc injectors, walbro 450L, Z32, Nistune etc... All about 2000km old.
    • I always wonder where the obsession with legal/illegal spacing on number plates in the UK comes from. Because it comes up in comments in every UK-based video I see on youtube. From my point of view all of your plates look a bit odd. Just because there are no markings whatsoever. In Australia we have the state that has to be on it. In Europe you get stamps and state logos. Yours look a bit like a throwaway draft that people then stuck with. And attached with blu tack so that it falls off at the slightest disturbance. Not trying to hate, but it's interesting how things are done in different countries. Do you have to follow a lettering convention when choosing a custom plate?
    • Hybrid sounds like a supercharger... It's half a turbo, with a belt to drive it! Oh wait, they're just called super chargers...
