Natural habitat for a Nissan Skyline as she spends most of her time on jack stands waiting, waiting to be fixed or used. Other Nissan Skyline species will sit for years on car hoists and get pushed or tow from hoist to hoist often not being started for years as well.
  • Like 5
Yep, it's been having a sads on the ground for a week.
it's not getting an EFR as it costs as much as the siet bok :(
Dose wise, should be a least a 82% increase, might need to change my alias to Sutututututututututu :D
  • Like 1
So since we moved into this townhouse I've had to make do without a double garage and no tool wall :(
This means all my tools are in boxes, a caddy, all in their tool blow moulds instead of nicely hung up on the wall which provides easy access. Each time doing anything small or large on the car meant 5 minutes of unboxing shit and leaving it askew all over the place. This makes for one angry Dose Pipe.
Missus detected a problem and she delivered on this for Christmas, 11/10 effort.
(yep turbo still on the ground, been too lazy and busy and be lazy to wrap it up and send it back to @hyper-gear sorry Tao!)
  • Like 4
On 29/12/2016 at 6:11 AM, Dr. Surge said:
Maybe stupid question but i can't seem to your other topic, but which intercooler are you running atm?
never a stupid question :)
I'm running a cheap shit bok HDi core (pretty much Hybrid) their original China 10000000x special... intake temperatures are horrendous, at 1.8bar of boost I'm logging down over 60 degrees with ambient dyno room temps of 20 degrees... nevertheless E85 is the best band aid in the world!
Will be upgrading to a better Plazmaman core one day, ironically I sell them but don't use them.
  • Like 1
Haha :P pretty ironical that you don't use them yourself ;) 1.8 bar ... stock RB25's aren't as weak as some peoples blame tho ... :8_laughing:
  • Like 1
  • 3 weeks later...
So yeah update, both intake and exhaust manifolds are off, so is the wiring loom for the engine...say what? let's play guessing games for the below image.
  • Like 3
Tao from @hypergearfound bits of piston inside the turbo's turbine housing. So the turbo failure wasn't actually from over speeding the wheel, nor was it from all the anti-lag launches, nor was it from the ignition cut only rpm limiter, it was from my engine spraying out bits of motor shrapnel.
Last time I did an oil change, I did recall similar pieces in the sump but pass that off as oil pump fragments lol.
So yeah, motor is coming out and not sure on what to do.. There's the NEO option which is easy, but Tao is sending me back even a larger turbo so that might go bang too, or do I just go fark it RB30?
Missus won't be happy with any option except NEO because it's our money not just mine lol.
Oh dear.
If it's our money and not rocking the boat is an issue, go the NEO route and just don't lean as hard on the new turbo, keep the power sensible and enjoy it.
OR accept that it will be off the road longer, keep saving and go RB30.
Just depends on if you want to wait I guess?
You do some built RB30 long blocks pop up from time to time cheapish.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
