Natural habitat for a Nissan Skyline as she spends most of her time on jack stands waiting, waiting to be fixed or used. Other Nissan Skyline species will sit for years on car hoists and get pushed or tow from hoist to hoist often not being started for years as well.
  • Like 5
Yep, it's been having a sads on the ground for a week.
it's not getting an EFR as it costs as much as the siet bok :(
Dose wise, should be a least a 82% increase, might need to change my alias to Sutututututututututu :D
  • Like 1
So since we moved into this townhouse I've had to make do without a double garage and no tool wall :(
This means all my tools are in boxes, a caddy, all in their tool blow moulds instead of nicely hung up on the wall which provides easy access. Each time doing anything small or large on the car meant 5 minutes of unboxing shit and leaving it askew all over the place. This makes for one angry Dose Pipe.
Missus detected a problem and she delivered on this for Christmas, 11/10 effort.
(yep turbo still on the ground, been too lazy and busy and be lazy to wrap it up and send it back to @hyper-gear sorry Tao!)
  • Like 4
On 29/12/2016 at 6:11 AM, Dr. Surge said:
Maybe stupid question but i can't seem to your other topic, but which intercooler are you running atm?
never a stupid question :)
I'm running a cheap shit bok HDi core (pretty much Hybrid) their original China 10000000x special... intake temperatures are horrendous, at 1.8bar of boost I'm logging down over 60 degrees with ambient dyno room temps of 20 degrees... nevertheless E85 is the best band aid in the world!
Will be upgrading to a better Plazmaman core one day, ironically I sell them but don't use them.
  • Like 1
Haha :P pretty ironical that you don't use them yourself ;) 1.8 bar ... stock RB25's aren't as weak as some peoples blame tho ... :8_laughing:
  • Like 1
  • 3 weeks later...
So yeah update, both intake and exhaust manifolds are off, so is the wiring loom for the engine...say what? let's play guessing games for the below image.
  • Like 3
Tao from @hypergearfound bits of piston inside the turbo's turbine housing. So the turbo failure wasn't actually from over speeding the wheel, nor was it from all the anti-lag launches, nor was it from the ignition cut only rpm limiter, it was from my engine spraying out bits of motor shrapnel.
Last time I did an oil change, I did recall similar pieces in the sump but pass that off as oil pump fragments lol.
So yeah, motor is coming out and not sure on what to do.. There's the NEO option which is easy, but Tao is sending me back even a larger turbo so that might go bang too, or do I just go fark it RB30?
Missus won't be happy with any option except NEO because it's our money not just mine lol.
Oh dear.
If it's our money and not rocking the boat is an issue, go the NEO route and just don't lean as hard on the new turbo, keep the power sensible and enjoy it.
OR accept that it will be off the road longer, keep saving and go RB30.
Just depends on if you want to wait I guess?
You do some built RB30 long blocks pop up from time to time cheapish.
    • Thanks man, I appreciate that. I'll keep it in mind going forward, important to know.
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
