Baffled Sump by the look of it? I always liked the prospect of the HOR extended sump but I read its a pain in the ass and can only be fitted with the engine out. Lucky you're already there ;)
Baffled but not gated, feeling a bit poor haha.. Yeah you "could" do it motor in but at that rate you might as well take the motor out.
Some progress tonight, I removed the crank. Some scoring on the bearings so might change all of them too :(
I was hoping on the conrod bearings needed changing but YOLO right? I still want to retain the standard NEO rods and NEO pistons because they said not to let the Nissan out *ahem* @GTSBoy, @Piggaz. Nissan hasn't been let out lol.
Oh hai! Looks the goods, sump was modified to suit the AWD motor going RED as the pick up sits more forward. Test fitting was spot on, I like very much - great success.
Off to the machinist it goes, the silly crank.
43 minutes ago, admS15 said:
Nissan is well and truly out now brah. You've contaminated it with Sydney air. Should be alright though. #RBLIFE4EVA
Still stock!!!
Crank at shop, but their machinist has buggered off overseas for 4x weeks!
Thinking if I should do connecting rod bolts too lol.
Still stock motor :)
  • Like 1
Are stock bolts capable of 400rwkw?
If no, then replace.
Given the driving style I'd worry more about balance/harmonics/oil pump strength etc.
Unless the rod bolts are a known weak point?
Got a good balancer for it?
1 hour ago, Dose Pipe Sutututu said:
derno, Matt Wooten & TIm Burt don't seem to have issues with stock oil pump, stock rod/bolts
Soooooo why did you pull it apart if these guys have been trucking along for years with the stock setup?
just to install the Spool oil pump gears and to install a new head gasket - that was it :)
May have gotten a tiny bit carried away with the headwork but that's just it.. everything else is just pretty stock
  • Like 1
Actually had free time for a change, which I rarely do.. so decided to do some work on the siet bok rust bucket.
I always has an issue where the camber kept changing every track day and I had a feeling the OEM camber bolts were moving so I decided to deleted the bastard with this GKtech camber lock out kit.
On removing the OEM camber bolts it was evident the machined groove and offset washer weren't working correctly, most likely slipping when I'm smashing into ripple strips.
Man 60% of yhe arms are Hardrace lol.. bastard should sponsor me!
  • Like 2
Yeah cnuts!
Removing those stupid machined screws are not fun, used those impact/hammer screw drivers and a bit of heat. I bashed the shit out of the pump like Pacquiao vs Horn and eventually all of them came out.
Yay, it's not broken but who cares we are going billet!
Result? Billet oil pump gears, hectics bro - can smash limiter all day like a JZ now!
  • Like 3
    • Like others have said, drop the power to give your drivetrain a % of reliability until you can up the drivetrain reliability  It isn't rocket science, build power to the weakest link with a % of safety Whilst upping the the reliability of the drive train is costly, there's no point in having the engine make big power if it keeps eating the drivetrain....ask me how I know, I had the tow truck on speed dial for a few years, and I spent huge amounts of money fixing issues and breakages that really would have been cheaper in the long run if I did it right the first time Me, I like a nice sized fudge factor, that keeps me off the tow truck
    • I don't understand what the issue is with, turn the boost down and start saving $$.  As soon as you can afford the supporting mods, turn the boost back up.  If the car is running fine, enjoy it. Turning the boost down isn't going to kill you.
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
