More OEM goodness, special thanks to Andrew @ Kudos Motorsports for the parts. Cheaper, faster than Nissan themselves so winner in my books!
Ooo.. The dowels are in, more soon :)
Stock pistons look good after a clean ?
  • Like 3
Oh yeah, ARP 2000 studs and Tomei head gasket. She's now sealed up :)
One last time to admire the head before it gets all dirty
Sealed up, time to get everything else on before December. Because we all know how useless I become in December lol
  • Like 3
8 hours ago, admS15 said:
Edward would cum his pants lol
Can't wait to dose again, with an older GT style compressor wheel it will dose great ??
  • Like 3
Last night's efforts involved getting the timing kit on, checking all timing marks and getting the tension of the belt on correctly. Alternator and water pump ancillary belt on too!
Yes I know it's a Gates belt, part of me remembers I ordered a stock belt but after opening the package just the other week after a year it got me by surprise lol. Maybe the guys at 999 Automotive packed the wrong thing or I actually ordered the wrong kit, nevertheless it's on!
Brand new crank pulley on too, none of that fancy Ross business either. OEM should be good for the "stock" motor lol.
  • Like 3
17 minutes ago, GeeDog said:
Looking good. Where did you get the drip tray that fits over the engine stand - looks like a good idea.
I borrowed it from my mate haha.. I think he got the lot from Burson's
The quicker I get this shit box done, the quicker I can throw it on the dyno and start tuning it. Started to get the itch, thus the build thread is moving a bit faster.
Already altered my existing map for the new motor, predicting it would be a little laggier I've flattened the timing instead of ramping it once torque decays
nice bits...
the question is...will you be able to keep up with the ricecake at wakie.....
i'll be holding it flat through the kink with ~310kw m8...then hard on the brakes & hot into the first corner....powering out with the force of 1000 naprec's
  • Haha 1
Le Siet Bok never stands down a challenge, this heap of shit barge is made for the straights! *cough* Powercruise, Roll Racing, WSID lol
In seriousness, should be able to be competitive at Wakefield, hopefully dip into the 1m5s~6s with a proper driver.
  • Like 2
Man I'm getting tired of putting this croc of shit together. Constantly sleeping late, skipping gym and smelling like a degreaser meth lab lol.
Tonight's effort: cam baffle plates, half moons, cam covers, cas bracket and sealed up the sump.
I ended up with 2x 10mm dark bolts that have rounded ends after the thread finishes. Not too sure where they go lol.
  • Like 5
Looks mint. I have some spare rb25 covers (which have been gutted internally to fit a 26) that are perfect for putting in an engine so you dont mark your freshly painted ones... but looks like the new ones are permanently on!!!
5 hours ago, niZmO_Man said:
Isn't building an engine a workout anyway? :P Just dead lift the engine or squat with the head or something.
I've actually injured my back several months ago... these days I'm deadlifting what my missus does at the gym and it's a struggle :(
Great work on the engine.
Brb checking if mine still in car as this engine is looking way too similar :P
  • Haha 1
So close yet so far, typical NBNish delivery lol.. Over budget and project schedule blown out of the water.
Got the hot side on, then found out drain doesn't fit lol... Fine, eBay some dim sim goodness, should arrive soon.
Then go and fit the coldside, started to look good.. Then yep, just my luck all thr injector boss o-rings are cracked from prolong exposure in my tool box. Decided to Yolo and ordered 1550cc Bosch injectors, Plazmaman rail and now will remove the R33 plenum and fit the R34 NEO plenum instead, this means I no longer need any injector bosses. Another delay sigh...
Oh yeah these are the two bolts that came back with my head when I got it machined and tickled, anyone have any idea where it goes? Lol
  • Like 2
7 minutes ago, ActionDan said:
o-rings don't fit, nek minnit all new cold side lol
That's how the NBN is being rolled out lol
  • Like 1
  • Haha 1
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
