49 minutes ago, hy_rpm said:
Offt! shitbox
Almost a $50k build i wouldnt sell it not worth it
Is there a sneaky 3.2L stroker here you aren't telling us about?! ?
2 hours ago, Dose Pipe Sutututu said:
Decided to update my spreadsheet, turns out "cheap shit box project" isn't so "cheap" after all.
At least you arent in denial about what you have spent lol
20 minutes ago, admS15 said:
Im clearly doing it wrong... Still below 20k brah.
Not including consumables like brake pads and tyres.
Mine doesn't include tyres, pads, maintenance shit either :(
Keys were handed to a mate whilst it was in New Delhi. Safe to say the clutch, gearbox and engine seem to be working well.
  • Like 4
12 hours ago, V28VX37 said:
8/10
Would have been 9 but needs more gauges
More like needs a working tacho Hahah.. At present rev limiter is at 8300rpm soft cut and 8500rpm hard cut.
#becausehonda
  • Like 1
Gifts run pre Lunar New Year (yes I'm Asian and no I won't go back to my country becasue I'm already here ?).
Still no time to throw it on the dyno yet but AFRs are in the low 11s and timing isn't anywhere even barely close to a stock map (actually used my old map and flatten the timing due to cams).
  • Like 2
All i can say is LOL.
Without an idle correction rate vs. timing compensation table, getting the car to idle this smoothly wasn't easy! Had to pull a few Microtech tricks haha
  • Like 1
y u no lumpy
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
    • You think its the AFM? I know its a common issues on R32s. I find it coincidental how this issue raised right after cleaning the fuel system. As everything except the fuel system was fine before. I tried running it with the IACV unplugged but did not notice a difference and still stalled. However, the RPM gauge is not in the cluster right now, so I will need to connect the laptop again and use Nistune to check the RPM. I will check this weekend.
    • A wise man once told me, "Anything you enjoyed wasting was not wasted".
