49 minutes ago, hy_rpm said:
Offt! shitbox
Almost a $50k build i wouldnt sell it not worth it
Is there a sneaky 3.2L stroker here you aren't telling us about?! ?
2 hours ago, Dose Pipe Sutututu said:
Decided to update my spreadsheet, turns out "cheap shit box project" isn't so "cheap" after all.
At least you arent in denial about what you have spent lol
20 minutes ago, admS15 said:
Im clearly doing it wrong... Still below 20k brah.
Not including consumables like brake pads and tyres.
Mine doesn't include tyres, pads, maintenance shit either :(
Keys were handed to a mate whilst it was in New Delhi. Safe to say the clutch, gearbox and engine seem to be working well.
  • Like 4
12 hours ago, V28VX37 said:
8/10
Would have been 9 but needs more gauges
More like needs a working tacho Hahah.. At present rev limiter is at 8300rpm soft cut and 8500rpm hard cut.
#becausehonda
  • Like 1
Gifts run pre Lunar New Year (yes I'm Asian and no I won't go back to my country becasue I'm already here ?).
Still no time to throw it on the dyno yet but AFRs are in the low 11s and timing isn't anywhere even barely close to a stock map (actually used my old map and flatten the timing due to cams).
  • Like 2
All i can say is LOL.
Without an idle correction rate vs. timing compensation table, getting the car to idle this smoothly wasn't easy! Had to pull a few Microtech tricks haha
  • Like 1
y u no lumpy
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
