Tiling done, toilet fitment done, paint nearly done.
Now for the cabinets, then bench top and then maybe finish off the R33 heap of shit.
Needed to do laundry before our trip to Tassy, at least the laundry is functional haha
If your wondering why some parts aren't painted it's because the cabinets are going over it. The parts in prep/prime are for the splash back tiles.
Toilet in, sealed up and ready to be shit in
Also Supercheap flash sale, so I went to town. All of that under $80 [emoji3059]
Toilet seat isn't even up....next thing will be a picture of lamps that match the ornamental cushions
  • Haha 3
On ‎5‎/‎12‎/‎2019 at 6:35 AM, Dose Pipe Sutututu said:
Yeah, started renovating the laundry, nothing better than spending money when you're not making money lol
How difficult is it to get the tiles off the wall without completely stuffing up the plasterboard?
2 hours ago, Count Grantleyish said:
Is the brown thing on the floor your skid marks?
Haha nah that's wood stain that the Mrs spilt everywhere.
Rage 11/10, had to regyprock half the bottom wall around the sides!!!!
  • Like 1
But all good things don't last, I'm back to work tomorrow. Ended up with a 2.5 contract role until our 5 week Europe trip.
A little bit of coin helps I guess.
  • Like 3
On 5/12/2019 at 7:42 PM, Dose Pipe Sutututu said:
@WantGTR more reno pics as requested, tile on tile for the floor.
Prep & Prime on and a mock of how the tiles might look.
Mate, as a  foreman working with a Tier 1 this is literally the dodgiest way to renovate a bathroom, STOP.
And before you flame me, the owner of the unit I'm renting did the exact same thing and the bathroom now leaks like niagra falls.
Please explain how you'll do an Australian Standard detail around the floor waste, oh wait you can't. Water ALWAYS gets in around & underneath and you may as well have blown a headgasket mate.
F**king stop dude, rip the existing tiles up, minimum two coat waterproof system and lay on the proper substrate. Otherwise it will devalue your property.
Never tile against tile.....NEVER, & you'll thank me later. And if you don't listen, watch in 1-2 years when your walls become soaked (and if you live in an apartment block feel the wrath of strata).
It's a laundry. I assume that he would tip water down the sink rather than straight on the floor. (or do people tip it on the floor? I don't know)
it's not a shower, it's barely going to be wet. Why wouldthe walls be ruined in 2 years?
  • Like 1
  • Thanks 1
Also it's a town house, the laundry is on a solid slab too and ground level. As Ben stated, all the laundry waste would go directly into the drain not on the floor.
If it were a shower, it would be very different :)
  • Like 1
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
