Doing some basic tuning for now, double demerits too so don't want to risk my license.
Cars running on 7 month old E85, and seems to have developed a misfire with 1.4bar boost and above.
It's recently also got R35 coils and I've dialed up the dwell however it's still missing.
About 1.2/1.3bar it seems "ok", but I'll get it back on 98RON for a bit to clear up the system.
1bar at ~4000rpm
1.3bar at ~4300rpm
Noting the AFRs are shit house and I probably could still feed it a good amount of timing. Good to be behind the wheel again, and fuuark the dose is so good.
It sounds like a bus dosing, just goes suuuuuuuuuuuu when you back off lol
  • Like 1
23 minutes ago, Dose Pipe Sutututu said:
Back to reno photos, stone is now in.
Without doors
With doors
Looks mad, how many Litres/KG of load so you get with that washer? Have you thought of tuning it a bit to get some more spins out of it?
21 hours ago, Murray_Calavera said:
That was a bit of a tease, let's see the timing table as well lol
Ask and you shall receive :)
Base Table
Compensation Table aka E85 table
  • Like 1
Came to check out the car. Strangely intrigued by the laundry.
Where can I get some of that gourmet xúc xích pâté?
Sullivan's Cove, quite difficult to come by. How is it compared to the French Oak? Looks fancy.
Haha that pate was made by my wife and I at the Agrarian Kitchen in Tasmania, 2 day cooking class.
I actually got the bottle at Sullivan's Cove (as in the distillery itself). I can't remember the taste now lol.
Anyhow, one more laundry photo lolol.
  • Like 1
18 minutes ago, Ben C34 said:
When that laundry is 400mm underwater the tiles will fall off and you won't be able to sell your house ever.
Not sure I get what you're trying to say?
This isn't a don mega laundry.
This is bok choy laundry.
  • Like 2
  • Haha 2
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
