Doing some basic tuning for now, double demerits too so don't want to risk my license.
Cars running on 7 month old E85, and seems to have developed a misfire with 1.4bar boost and above.
It's recently also got R35 coils and I've dialed up the dwell however it's still missing.
About 1.2/1.3bar it seems "ok", but I'll get it back on 98RON for a bit to clear up the system.
1bar at ~4000rpm
1.3bar at ~4300rpm
Noting the AFRs are shit house and I probably could still feed it a good amount of timing. Good to be behind the wheel again, and fuuark the dose is so good.
It sounds like a bus dosing, just goes suuuuuuuuuuuu when you back off lol
  • Like 1
23 minutes ago, Dose Pipe Sutututu said:
Back to reno photos, stone is now in.
Without doors
With doors
Looks mad, how many Litres/KG of load so you get with that washer? Have you thought of tuning it a bit to get some more spins out of it?
21 hours ago, Murray_Calavera said:
That was a bit of a tease, let's see the timing table as well lol
Ask and you shall receive :)
Base Table
Compensation Table aka E85 table
  • Like 1
Came to check out the car. Strangely intrigued by the laundry.
Where can I get some of that gourmet xúc xích pâté?
Sullivan's Cove, quite difficult to come by. How is it compared to the French Oak? Looks fancy.
Haha that pate was made by my wife and I at the Agrarian Kitchen in Tasmania, 2 day cooking class.
I actually got the bottle at Sullivan's Cove (as in the distillery itself). I can't remember the taste now lol.
Anyhow, one more laundry photo lolol.
  • Like 1
18 minutes ago, Ben C34 said:
When that laundry is 400mm underwater the tiles will fall off and you won't be able to sell your house ever.
Not sure I get what you're trying to say?
This isn't a don mega laundry.
This is bok choy laundry.
  • Like 2
  • Haha 2
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
