Shit, that's pretty decent - nice work :)
Edit:  What was responsible for the speed readout on the video?  A bit odd that it got you at a peak speed of 161-162kph when you trapped at 108mph lol
Edited by Lithium
All in the LC, Flappy Paddles and Carpark reflash lol.
That's from a Garmin VIRB camera, no idea how accurate it is but I can't imagine it being very accurate.
  • Like 1
Taubmans Trade X paint, not bad. Nice viscosity (consistency in cooking terms lol) and cheaper than Dulux.
Still a bit wet when I snapped up these pics.
5 year reno, did everything, painted the walls but never  bothered to paint the ceiling, guess it's a good time to do then the cnut is up for sale aye.
Study next, then following weekend got a mate coming to help smash out the dining, kitchen and living room ceiling in one go.
  • Like 1
Way to slow !
It died last week.
And as my car is a daily I had to reco a 9 puck steel Nismo flywheel I had spare in the garage.
Its now in and Ive got to look at recoing my Carbonetic Carbon twin plate for the 3Litre
Feeling for you mate, and anyone in a similar situation.
Im glad I work in IT at the moment, even though its absolutely nuts at the moment, my job is very secure, and fully function able from home.
Keep safe everyone
  • Like 1
Yeah man, wifey is a commercial analytics manager, great for helping the business grow and find ways to increase revenue/profits... but during this period of uncertainty most companies won't be even making profits so yeah.
R33 is also a form of luxury, so that needs to go.
11 hours ago, niZmO_Man said:
Where? I skipped through it and didn't see your car. Also the music sounds like it was recorded with a busted sub. Or maybe that's just my speakers...
0m36s mark lol
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
