$850 later, ready for garage parking competition.
New seals, new bearings, added 2x shims, backlash reduced a bit.
Just need to redo the ABS wiring, sometime in the past (not during my ownership) someone cut the plug and rejoined it poorly. When I put in the 2 way centre I never bothered to fix it because the mindset was "cheap track car, don't care". Fast forward 7 years or so it's not a very cheap track car anymore ?
  • Like 1
4 hours ago, ActionDan said:
As if not keep it for your next nugget track day special
He's all about Don Mega spec with Samsonas now.
  • Haha 2
11 minutes ago, ActionDan said:
Given the price, you gonna lash out and just go new?
Would be a sensible approach, however when you think about it.. most 350/370Z don't produce very much power. Given that assumption, you would think the boxes are less thrashed than a Skyline box.
Kind of how you would compare a high class escort to a hooker around the bowlos.
1 hour ago, ActionDan said:
I got 2 updates in 2 threads, both posts from you, both posts banging on about Samsonas...
Do you get a commission or what?
I wish :(
On 8/24/2020 at 12:50 PM, Dose Pipe Sutututu said:
Imagine I did, just imagine that!
But reality, this non-Don Mega Ham build will probably just end up with a 350Z CD009 box.
fisch automotive are making RB conversion bellhousings for CD boxes at the moment, im very interested
  • Like 1
Someone should do DQ250/381/500 conversion bellhousing for RB's.
I feel it'll go well with AK47/crackle maps.
Nailed it, I'll take the DQ500 thanks.
If the one in the boat falls out, just pull it out from the missus' Tiguan and I'll be good again.
  • Like 1
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
