New day, new excuse to waste money.
Car going to fab next week, and somehow a simple "hot pipe extension & new cold side" is now involving a new catch can, new pipe work, relocating shit, reinforcing the subframe, etc.
I honesty think a cocaine addiction is cheaper and provides more happiness and mental health :D
  • Like 2
On 29/10/2021 at 11:24 AM, niZmO_Man said:
yeah but can you drive cocaine?
you can, have enough and you'll be floating LOL
Then again, can you drive the Skyline? the only time I drove it in the past 12 months was onto a tow truck, off the tow truck and reversed it up my driveway.
You make some very good points 😭
I don't drive my car because I have to get it re-insured for a decent value, not what it was worth 8 years ago
  • Haha 1
If we all had M2/3/4/5 we would use them!
  • Like 1
As if anyone would aggressively drive something like a M5 on the track. Even price inflated Skylines are nothing compared to the costs of running/maintaining/replacing something on those lol.
I just built my own E39 M5 :P for the budget conscious gentleman!
Mate just sold his 33R weekender and bought an 09 C63, reckons it's better in basically every way and now he dailies it. Srck6 exhaust sounds ridiculously good 0_0
  • Like 1
your friend's a drug dealer?
actually I said the same to the neighbour's kid when he turned up in one. went down like a lead balloon. turned out he was.
  • Like 1
  • Haha 8
New day, new tow truck adventure 😂
Off to (more) fab work, at the same time I thought why not take out the subframe and weld in extra plates for strength and replace all the bushes (again) since they're all McFked.
This time round, I'm not using Superpro polyurethane diff bushes and going with harden rubber. I don't think the polyurethane stuff is up to the abuse I throw at it. They've all deformed, some cracked and cause the diff to move around now. As for the subframe bushes, I'm just replacing them with the GKTech harden rubber ones (currently Hard Race ones) as it sits the subframe a bit higher, meaning I will have ever slightly more closer to OEM geometry. I need all the grip I can get here 😊
  • Like 2
On 05/11/2021 at 11:49 PM, r32-25t said:
That’s not that hard a Hyundai is better then a bmw
Fk the hate is strong with this one 😂😂😂
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
