On 15/08/2022 at 2:13 PM, Dose Pipe Sutututu said:
Kind of can, I have a feeling there will be max level of anxiety on the day lol...
I have a Garmin VIRB which tracks a few data points such as laptime, speed, Gs, etc.
yeah ok cool
Harry's laptimer is pretty cheap for what it is
https://www.gps-laptimer.de/products
If you just want video with overlay the Petrolhead version is like $20
I got the full Grand Prix version at like $30, just more features i may or may not use haha
  • Like 1
See how I go, if I start to get back into circuit racing like before I might just buy this:
https://www.garmin.com/en-AU/p/690726
On 15/08/2022 at 2:19 PM, ActionDan said:
Race Chrono (paid) gets my vote, controls the GoPro as a rempote and does overlays on the video for you.
Nice, I havent used Race Chrono.
Harry's does multi cam too, with video in video. But havent played with the 2nd camera options yet. I do have a gopro8 so may be something ill try down the track.
Watching these replays has really helps improve my driving lines and lap times.
Damn!! Maybe worth while if you were a pro driver
Overkill for us weekend warriors haha
I know someone who has one and its amazing but he is funded by bank of dad and is serious about getting to supercars.
Takes video of fastest parts and makes a perfect lap, will tell you when to brake too.
  • Like 1
"Takes video of fastest parts and makes a perfect lap, will tell you when to brake too."
thats a pretty cool feature.
Let's just say that private track day, I might have one of those strapped in the car for testing 😎
I'll reveal a bit more after the day.
  • Like 2
Awesome, be good to see how you go.
On 15/8/2022 at 12:47 PM, Dose Pipe Sutututu said:
Lunch time tingz
Added stickers 😅
Now I need to see if R33 and C34 have the same ashtray as that fits well
Doooo it, you need it lol.
Just a note, you need to clearance the trim to clear the Deutsch connector but nothing a 22mm hole saw bit can't fix.
So does trackaddict, though I would suspect RaceChrono paid (which I also have) does well, but trackaddict also overlays OBD2 data from the car if you want that too. Maybe Racechrono does. Point being, get it setup right and all you have to do is hit 'record' and your video and telemetry gets synced and life is good.
Will see how well this all works for me on sept 2 :P
  • Like 3
Latched Launch Control. G4+ and G4x have this feature. Just push and hold the button and the engine won’t rev passed that point.
I have it installed for roll racing, grab the button at 4500rpm+ and it will make boost then release for warp speed
  • Like 1
    • You now say stumble, but you said cut out before. Will it slow rev through the cut/stumble? What gap were your spark plugs set to when you them in?
    • I had double clamped all the pipes but I checked them over any way, everything tight and secure. feels and sounds like a electrical short/failure, as it is an abrupt and aggressive stumble, that instantly comes and goes right at 4k mark...like clock work fuel pump and filter are new new coils and plugs injectors where cleaned and tested 200 miles plus ago no black smoke cleaned MAF   same results, other ideas? some other sensor?
    • Yes, just without the annoying use of the word hybrid. We stopped using that term 20 years ago when we realised it meant different things to different people. Even "highflow" can represent more than one way of achieving the goal of getting more flow out of a turbo. But at least it says what it does on the box.
    • OH, when they say "solid buckets", I always interpeted that as "shimless". (Which is not the same as the "shimness word I invented above to represent the same idea that the buckets act as shims also!!). Still the same problem though. So it appears that buying a "kit" from Tomei is a two step process. Makes sense. Doesn't make sense in the context of a "kit" though.
    • Wanted to add some of my R33 GTST  R34 GTR wheels, 18x9 ET30 with 255/35/R18 PS4S'   BBS RE-V7 029 18x9.5 ET22 with 255/35/R18 PS4S' Needs a bit of camber
