Race seat back in, shit is getting real.
For those curious, it's a Bride Zeta III Plus, made for people bigger than the average Japanese racer.
  • Like 2
On 20/08/2022 at 5:37 PM, Piggaz said:
Seats look bulldog. Comfy enough to sit in them for 3 hours without getting back cancer?
It's not bad, much more comfy compared to the usual Zeta seats. Space wise, I would say it's comparable to the Recaro Pole Position (waist, arse area) but with a larger top area for broader shoulders.
I have a bad back, and any car seat that's not OEM will give me back pain in about a hour.
On 20/08/2022 at 6:12 PM, Piggaz said:
Is there a passenger one coming? It has to match Farken!
I'm planning on going twin recliners. So yes there will be matched seats, but not a pair of fixed buckets.
This is just a stop gap until I get a pair of recliners.
Maybe Recaro Sportster CS 😍
Got a set of them in the mrs focus rs, awesome seats but a bit of a pain to get out of at times
  • Like 1
They are, but for some light track work, they offer decent support. I used to have a Recaro SR3 in the shit box and it was hopeless for Wakefield. I would be trying to push myself into the seat another corners instead of trying to steer.
On 20/08/2022 at 6:19 PM, Piggaz said:
It’s only a 14 mm socket x 4 bolts to change them.
mix and match for what the duty is. 🤷‍♂️
It's a space thing, will now need to leave the stock seat at the in laws.
Joys of Sydney, pay for air not land.
  • Sad 1
Couldn’t fave said it better. Overpriced shithole it is.
  • Haha 1
That’s a harness thing. Having good seats is one thing, being stuck in them is another
Yes and no, the Zeta 3 Plus holds very well for lateral movement when compared to a Recaro SR3 or a Bride Brix (used them both also real ones not fake ones).
I agree a harness will improve being planted in the seat.
On 21/08/2022 at 8:06 AM, Murray_Calavera said:
Speaking of harnesses, are there any plans for half cage and harness?
There are plans for it, been a plan for a while lol.
I really should just do it, mainly for safety. Especially now I'll be easily doing 220 to 230km/h down the mainstraight at Wakefield Park (provided it even stays open now due to all the issues they're having).
  • Sad 1
Just make sure if you get a harness you get a HANS. Then there's all sorts of extra things to consider like a helmet net and proper collared seat and etcccccccccccc.
Just adding 1 can be less safe than adding 0, but I am sure you know that already.
  • Like 1
Ohh noooos, it's only just got all nice and shiny.....and working.....again
When you going to take it to WSID and race me for a bag of donuts
RWD JDM speed boat vs RWD AUD cruise ship
No drag radials, but semi-slicks are GTG
I've also got a tilt tray on speed dial so we are both good there....🤣
  • Like 1
  • Haha 2
My current AGV helmet is looking rather sad, will definitely get modernised gear soon enough.
Can't put a price on safety.
  • Like 1
100000% this
A helmet with Hans post can be found for 450ish (racelids) but bell is around 1100ish last time looked and a Hans around 400. Definitely get harness suited for Hans 2 inch over Hans back to 3inch as heaps more comfortable. The raceworks/mvp ones are good value and buckles/adjusters are nice.
Looking forward to hearing how it goes on track. Going to pretty quick on the straight.
Edited by robbo_rb180
  • Like 1
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
    • Yes sir am asking is there possible way from aem tuner from wiring pins
    • Have you checked cam to crank timing and confirmed balancer marks are correct?
