Race seat back in, shit is getting real.
For those curious, it's a Bride Zeta III Plus, made for people bigger than the average Japanese racer.
  • Like 2
On 20/08/2022 at 5:37 PM, Piggaz said:
Seats look bulldog. Comfy enough to sit in them for 3 hours without getting back cancer?
It's not bad, much more comfy compared to the usual Zeta seats. Space wise, I would say it's comparable to the Recaro Pole Position (waist, arse area) but with a larger top area for broader shoulders.
I have a bad back, and any car seat that's not OEM will give me back pain in about a hour.
On 20/08/2022 at 6:12 PM, Piggaz said:
Is there a passenger one coming? It has to match Farken!
I'm planning on going twin recliners. So yes there will be matched seats, but not a pair of fixed buckets.
This is just a stop gap until I get a pair of recliners.
Maybe Recaro Sportster CS 😍
Got a set of them in the mrs focus rs, awesome seats but a bit of a pain to get out of at times
  • Like 1
They are, but for some light track work, they offer decent support. I used to have a Recaro SR3 in the shit box and it was hopeless for Wakefield. I would be trying to push myself into the seat another corners instead of trying to steer.
On 20/08/2022 at 6:19 PM, Piggaz said:
It’s only a 14 mm socket x 4 bolts to change them.
mix and match for what the duty is. 🤷‍♂️
It's a space thing, will now need to leave the stock seat at the in laws.
Joys of Sydney, pay for air not land.
  • Sad 1
Couldn’t fave said it better. Overpriced shithole it is.
  • Haha 1
That’s a harness thing. Having good seats is one thing, being stuck in them is another
Yes and no, the Zeta 3 Plus holds very well for lateral movement when compared to a Recaro SR3 or a Bride Brix (used them both also real ones not fake ones).
I agree a harness will improve being planted in the seat.
On 21/08/2022 at 8:06 AM, Murray_Calavera said:
Speaking of harnesses, are there any plans for half cage and harness?
There are plans for it, been a plan for a while lol.
I really should just do it, mainly for safety. Especially now I'll be easily doing 220 to 230km/h down the mainstraight at Wakefield Park (provided it even stays open now due to all the issues they're having).
  • Sad 1
Just make sure if you get a harness you get a HANS. Then there's all sorts of extra things to consider like a helmet net and proper collared seat and etcccccccccccc.
Just adding 1 can be less safe than adding 0, but I am sure you know that already.
  • Like 1
Ohh noooos, it's only just got all nice and shiny.....and working.....again
When you going to take it to WSID and race me for a bag of donuts
RWD JDM speed boat vs RWD AUD cruise ship
No drag radials, but semi-slicks are GTG
I've also got a tilt tray on speed dial so we are both good there....🤣
  • Like 1
  • Haha 2
My current AGV helmet is looking rather sad, will definitely get modernised gear soon enough.
Can't put a price on safety.
  • Like 1
100000% this
A helmet with Hans post can be found for 450ish (racelids) but bell is around 1100ish last time looked and a Hans around 400. Definitely get harness suited for Hans 2 inch over Hans back to 3inch as heaps more comfortable. The raceworks/mvp ones are good value and buckles/adjusters are nice.
Looking forward to hearing how it goes on track. Going to pretty quick on the straight.
Edited by robbo_rb180
  • Like 1
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
