Probably a good thing she's asked for a cage, only a few thousand dollar investment.
Yeah these shit boxes are old and rusty, even though they might visually look good they've had salt plastered on them.
  • Like 1
I've heard that story before too, the ripping through the floor bit, and I do recall seeing some pics at one point but I don't think it was an old jap car.
Either way, full weld in for me because dedicated race car.
I would be a bit more game to track a newer car with a harness bar/hans setup given all the airbags and improvement in safety cell design, but probs not an older jap car.
  • Like 3
2 hours ago, Jasoncauser said:
i wasnt allowed to buy a track car unless it had a cage (wifes rules) so I have a 6 point bond bolt in cage.
I have heard some horror stories of cages ripping right through the floor when (particularly older jap cars) landing on the roof dead flat in a rollover
Thats pretty good, we all need someone like that in our life.
Yeah a friend rolled a car at ebisu lucky had a cusco cage but it bent badly and was stuffed.
New cars are great for safety but still would want a cage at those speeds.
  • Like 1
Bond put in some large base plates inside and under the car to spread the load. I remember talking to them about it and they showed me a picture or a flipped car with a crushed roof, they then pointed out the base plates of the cage that punched through the floor. Not as good as the big stuff you see on a good weld in cage, but alot better than alot of the bolt in cages I looked at.
  • Like 1
Jim Richards gave a talk at one of SAUNSW dinners, and someone asked a question about times he's felt it was sketchy, or more so the sketchiest.
He recalled a time he raced Targa Tas. I think he said he was doing about 250kmh, and it started raining. And he said he thought "This is a bit quick, I should slow down... But to what? 180? I'm still gone at that speed..."
  • Like 1
the standard is alot better now for base plates with  minimum square area and length of sides. Still only as strong as the cars sheet metal.
😅 he would have had a full cage as its been a requirement for a long time.
He is right though
  • Like 2
100% yes.
My Bond Bolt-in cage has large plates inside and under. was rather impressed with it.
Especially 2nd had for $500. Came out of a hill climb car that had to upgrade due to regs etc.
Maybe its the placebo effect but i do "feel" safer with it in.
But its a tight fit. With padding on the bars, there isnt a lot of head room in a 32 coupe lol
  • Like 2
When you talk to @34GeeTeeTee you end up wasting money.
LOL.
HardoGhey camber arms, should help get camber to about -3° or so.
Didn't take a photo of the stock arms, but the bush inside was able to be rotated with my fingers. They're now both resting in my bin.
  • Like 4
LOL.
Haha but think about the stance brah!!
  • Haha 1
Shit box updates.
Alignment now done, driver side managed to get -3.5° camber and passenger side only -3.2° with the camber arms fully wound in.
I believe the knuckle bushes may be the culprit here, and yes yes @34GeeTeeTee I know I know, hammer hammer rubber hammer good lol.
Other than that, used a seatbelt harness bracket to mount the harness bar support to the floor of the car. Should be better that bolt/nut into the side of the body as there's much more material holding it. Used 8.8 tensile zinc bolts, should be "strong" enough.
I'll see how serious I get with track nights/days, if the car gets semis put on, then I'll put in a cage too as I would definitely be pushing the car much harder.
  • Like 2
Nice cambers. Probably is the upper knuckle bushes, chuck some of those adjustable Whiteline/Superpro ones in next time you go for an alignment. Doubt you'll feel a difference or would even know if you hadn't seen the numbers.
Where was said harness bar sourced from?
  • Like 1
Thanks bro, will definitely slap in some new bushes to give me peace of mind it's less shit.
I got it from eBay, here's the link 😊
https://www.ebay.com.au/itm/185659350438
Then bought these things to mount the support arms to the floor
https://www.ebay.com.au/itm/404023772773
I hope you never actually test this, but what are your thoughts on that harness bar and how it mounts, how do you think it would hold up in a big collision doing eastern creek main straight speeds?
I worry because I look at how CAMS spec out their bolt in cage requirements and harness mounting requirements (eg the plate that goes through the floor for the 5/6 point harness strap etc).
100% your car and your freedom to do what you think is best... but I still worry =/
  • Like 2
@Murray_Calavera from what I see, the harness bar, and 6 point harness (coming soon), will hold up much better than the factory restraint in a crash.
How I see it, it's better than OEM, so survivability increases. Even with a roll cage, on a frontal impact or side impact irs still game over. Will need a full cage to actually make a difference to safety.
Hopefully with Wakefield's new owners, we are all able to head back out there again, have fun at lower speeds.
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must me missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
