It's a compliance thing fitted in Australian so that you can only fit an unleaded fuel pump nozzle in it, normally they just glue them in and they end up leaking
What an amazing Track! Scary as for the 1st time. Those blind crests and double apex corners... Wow!!
Enjoyed it, but the car was a bunch of balls unfortunately on the day. Thanks to the SAU team who made it happen. Here is the pic of Daisy ATM... Gearboxout... dang.
I'll try and get some Video up of a few ok laps!
Great to meet some of you guys!
James
  • Like 4
OK Team,
Here is a Vid.  Lot's still to learn on that track, but I must say EPIC! @deongster there is heaps of you in here... enjoyed the duel you maniac!!
Once again, thanks SAU team for an awesome day.
GIVE IT THE BEANS!
  • Like 4
OK Team,
Here is a Vid.  Lot's still to learn on that track, but I must say EPIC! [mention=130368]deongster[/mention] there is heaps of you in here... enjoyed the duel you maniac!!
GIVE IT THE BEANS!
Hahha cheers mate. It was fun! Definitely! Hahah
  • 1 month later...
Didn't want to make a new thread but there is a track day listed under the skyline car club on the smsp website
Date is the 28th of august at the south circuit, apparently organised by skylines Australia.
http://www.sydneymotorsportpark.com.au/event/skylinecc-2/
Is that you guys?
  • 5 months later...
14 hours ago, GTRKat said:
@34GeeTeeTee better see you there teacup!
Depends when it is... And if you can babysit :laugh:
Hahaha because I'm so maternal.
Might have my hands full you know, running the day. :)
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
