Don't forget, R34 uses 14mm bolt holes.. so.. the AOR kit will need bolt sleeves OR tapped out to accept 14mm bolts.
Then.. your brake balances will be aids, we have set this up on a S15, running a BM57 and R33 GTS-t rear calipers. Car doesn't stop as well as my piece of shit GTS-t rust bucket running just basic 350Z Brembo calipers (same shit as R34 GT-R just offset a few mms out), not to mention it weights more.
  • Like 1
They're made specific to each car, if you're talking about the Alpha Omega Racing stuff, so if he has an R34 GTR then he buys the R34 GTR kit and bolt it on. Other than the bending (I prefer completely removing) the backing plate to make room for a larger rotor - which you must do for all brake upgrades - they are 100% bolt on, no sleeving no tapping no modifying whatsoever... provided you buy the right parts for the car.
Bias wise any front-only upgrade will move the bias forward - that's a given. Standard R34 GTR bias is 70:30 and R34 GTR NUR-spec bias is 68:32. With the matching front and rear upgrade the Evo 350mm Brembo bias is 69:31, this makes it a perfectly perfect bias. All the technical specifications are listed and also within contains a link to a 3rd party bias calculator for you to verify: http://alphaomegaracing.com/p/149/c/72/Z32/ALPHA-OMEGA/Evo-350mm-Brembo-Rear-Brake-Adapter-Kit-WTAC-Edition.html
If someone like Dan upgrades his R34 GTR to front and rear Alpha Omega Racing braking stuff, there are well founded reasons to believe the car will consistently brake/stop in a shorter distance + be more stable over any duration + have longer rotor and pad life.
I hope that information is helpful for somebody reading, cheers
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
