What causes did you find for body/suspension squeeks and clunks?
My r33 is modified and it does make a variety of noises while driving. I've just gone and replaced my coilovers for new, replaced my caster rods and even replaced the passenger side front lower control arm ball joint and to my great shock; all the squeaks and noises I had before, I still have! I'm especially confused as, in particular, I'm running out of things to replace on the front left, but I still have a clunk noise.
So it got me thinking, what parts of the car have you proven were the cause of squeaks, clunks or general body noise? What have you changed which has solved it? I love my car and want to get it as perfect as a 20 year old car can be, so lets share the ways to make it a more pleasant drive.
a common  and unexpected clunker is the shock top mounts, particularly if you either re-used the factory ones with your new coilovers, and also if they are new but are rose joint type they can start clunking surprisingly quickly.
also, it can simply be a loose nut on a joint that causes the clunk without anything being wrong bush-wise, so check them all.
BTW do you think it is front or rear clunk. rear clunk would most commonly be subframe or diff bushes
I was chasing an annoying squeak in my 4wd, you could hear it as you were driving along, looked at shocks, suspension, engine covers, you name it.....turned out to be the bonnet rubbers being screwed down a bit too much.  I give them more height so that the bonnet was a snugger [not even sure that's a word lol] fit and it fixed it.......not saying its one of yours, but its definitely worth a look.
To throw another one out there, I was getting a noise in my other car which sounded like a container ship groaning. By spraying WD40 on it to test (makes the noise temporarily go away) it appears its the rubber swaybar bush where the bar goes through which wears and causes that noise. I have new ones ready to install.
Back on me now, the clunk is front left (I believe) and although the coilovers are new, they are designed more for comfort than drift harshness, so I'm going to assume it shouldn't be them. I have replaced the tie rod ends and swaybar links in the last 2 years, so they should be in good condition, but I will have to check that everything is bolted on property and tight.
From the rear Im getting mostly squeeking noises. I have rear camber arms, a rear suspension brace kit, upper tower bar, aftermarket swaybar as well as metal subframe bushes. Ideas? Could it be else ware on the body even?
Yeah, stuff like this is good as I would never think to chase it to something like that
Almost a mission impossible, so many possible causes.
We were just chasing a weird squeak on my car after replacing the engine, sounded like a frog pond?! It turned out to be a heater hose clamp scuffing the firewall, doh.
Another thing that drove me nuts back in the day was a clear clunk when braking, which turned out to be aftermarket castor rod bush ID not matching the OEM bolt OD. Pro tip: Measure the bush ID of all suspension parts before throwing them in to make sure that it matches the original.
Also anything with a rose joint (i.e. most aftermarket suspension parts) will be noisy, compared to an OEM rubber bush.
And let's not even start on the mechanical diff...
27 yo R32 GT-R with a stack of miles on the clock (and probably a stack off it).
1. Door glass on hardened rubber
2. Door latch on striker plates
3. Bonnet rubber seals on cooling panel
4. Passenger searbelt retaining bolt loose
5. Centre console surround loose.
6. Steering wheel surround expands with heat and rubs.
7. Something in boot squeaks after about an hour
Another one I had was an annoying little rattle in the drivers door of the Skyline.  I looked and tightened everything, even stuck more foam on the door wire/rod latches...no fix.
More recently my rear view mirror stopped folding in, so I took everything out to fix it and duh duh....the front window guide/bracket rubber was torn and hanging.  You couldn't see itat all and looking down through the window sweeper gap it didn't show.
I ordered new brackets from the Brissy business [will add their name if I can think of it]  and fixed the rattle, so very happy.
Its like fighting a losing battle having an older car :(
or pretty much anything nissan. all my cars have a variety of sounds that change according to ambient temp. some days its silence, other days all sorts of random stuff rattles and shakes
I have a rattle behind the drivers and passenger ac vents. Its not always there but when it is.... its bloody annoying.
Whats even more annoying is it rattles with the vibrations of the motor at idle..
if the Ac comes on and drops the revs a little, it goes away, but is there at 950 rpm. which is where the car idles haha
One more I've read about and I'm sure people on here have had to deal with is the heater vent box? thing under the dash. Its fixable, according to threads on it but I hear the real pain is getting to it, often involving dash out. Lucky I don't have that one...yet
Update, I had a poke around the front left suspension and found that the swaybar link OD is slightly smaller than the swaybar and car ID so I believe that's where the clunk was coming from. The swaybar is aftermarket and I've tried to fix it as best I can but I think I need a proper go at it in the future. Also the whole car squeaks like crazy, so a winter job might be to try take apart everything suspension related, inspect, clean, lube as needed and refit. Its driving me nuts; good thing I have a loud audio system.
  • 1 year later...
Just thought Id revive an old thread. I always thought I was on top of the suspension side of things and most of it was all aftermarket or changed out within the last few years. Ive since learned that I had completely forgotten about my subframe bushes and while I haven't yet changed them out (will do soon), im very sure that this is the cause of a large amount of the noise ive been putting up with. Am changing out the diff mounts while im at it.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
