R33 S2 RB25DET FFP Install - HELP
Hi all,
First poster here :)
I've got a few questions about installing a FFP. I've got a stock R33 S2 with the usual (FMIC, BOV, POD, Coilovers) around 176,000kms on the engine. The engine itself is very healthy, running stock boost but pulls like a dream, always serviced every 5,000kms with Penrite 10W40 Racing 10, spark plugs etc by myself of course.
Now, I bought a FFP the other week, pretty sure its a Greddy remake, got it for a cheap price with all the fittings, screws and throttle body. Also bought the stock Inlet Manifold Gasket from Autopro just incase the one on is no good.
Basically I want to tidy up the engine bay a little as I hate the look of the stock plenums and the J-pipe crossing over the engine is a pain to take off every time to do spark plugs. I'm very mechanically minded, been around RBs for years, done a few things to them and done a few engine rebuilds etc.
So my questions are; anyone here done a FFP install themselves? How long did it take and what difficulties did you run into? Anything major to drill/reshape etc or just bolt on stuff? Where does the BOV get relocated to as the crossover J-pipe gets removed? Where do all the vacuum lines go?
If anyone can get back to me ASAP with answers or even videos that would be more than appreciated as I don't want to start something and end up not being able to drive my baby, looking at doing all this over the weekend, cheers guys! :cool:
NOTE: PICTURES WILL BE UPLOADED (ENGINE BAY, FFP, THROTTLE BODY)
https://www.sau.com.au/forums/topic/470140-r33-s2-rb25det-ffp-install-help/
There's a big how to thread in here somewhere. If you can't find it through the search function just Google. Get an adapter so you can use your stock throttle body. As you have bought it already I guess its a bit late to suggest putting the money towards a bigger turbo instead...
I've tried searching but nothing came up, also found one a few days ago through a Google search but it was pretty messy, how the guy did it etc..any pros to using the stock throttle body?
What turbo do you suggest? I want something capable of 350 - 400hp for street use with no huge lag!
The pipe from the intercooler to the throttle body will need to be remade. The bov gets installed before the throttle body on the new piece of intercooler piping and new pipe work will need to be made from the bov to the intake pipe, or don't bother reinstalling it and enjoy the flutters. The lines that are on the J pipe get installed on the new intercooler pipe and the lines that are on the stock plenum get installed on the freddy plenum, the factory lines probably aren't long enough so you will need new longer pieces of hose.
  • Like 2
Get a GTX3071 with the divided rear housing, then get 2x external gates on and sit the lot on a 6Boost twin scroll manifold.
Screamers out of the bonnet or side quarter for extra street cred :)
  • Like 2
the standard intake manifold will make the power goal you need,  so will the standard exhaust manifold.
Just get a bolt on turbo like what I have for sale atm,  install injectors and fuel pump and fmic.
FFP is not going gain you any power.
  • Like 1
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
