Loading up a track car
i have a 33gtst i use as my track car (pic below)
The car trailer i have makes it hard to load up as the ramps are to short and the front lip of my car hits when loading...
Its not as easy to put longer ramps on due to the design of the car trailer and how they are stored.
I dont want to make the car higher etc and im sick of putting my shit bumper on to load up
any ideas....? would finding a pair of 20s and chucking on some cheap tyres with a huge tyre profile lift it enough to get it on? finding 20s for a skyline could be tough that fit over evo brembos also
Any other ideas!?
https://www.sau.com.au/forums/topic/471151-loading-up-a-track-car/
A lot of people I've seen just remove the front bar in this situation, using Dzus fasteners or similar to make it quick and easy.
Otherwise, could try carrying blocks of wood around to help at the start of the ramp.
I feel like 20's with high profile will certainly have massive clearance/rubbing issues
I've got timber for my driveway. You have to reinforce it where it is lowest, and shave the ends so they sit flush against the two ends but they work well. And cost a grand total of $14 and one hour.
I should add we also used them for loading and unloading my car onto a trailer. Exactly as described above.
the easiest way to improve both the angle of the ground to ramps and ramps to bed of the trailer (where sometimes zorst scrapes) is to raise the rear of the tow car on caravan leveller/ramps or similar.  I've seen the same trick with a jack under the towball but I think that puts a hell of a lot of weight on a jack...
And if that's not enough go the blocks of wood suggested above at the start of the ramp, you can even have them flat on the ground as long as they are lower than the distance of splitter to ground on the car.
And if you can work out how to do it, long ramps are the real answer.  About twice what a normal trailer allows for is lovely.
  • Like 2
My car has a splitter on it and removing and re-attaching is a pain, I made 2 stage ramps with some handles from pine sleepers. They just sit on the trailer behind/in front of the car and are held on with tie downs.
Ghetto as but works and was cheap.
I could only find these 2 photos quickly and added one of the Silvia to show the splitter height. GTR clears it too.
The length was determined by how long needed to hit wheel before splitter edge hits timber.
I also have some of those little plastic Cusco ones that allow you to get just enough height to get a jack under it which is enough for people.
  • Like 1
I'd like to make a V2 that's lighter or I did consider running a drill through them to take core sections out but was worried about them cracking and splitting.
I am not a great builder/fabricator and have limited power tools so this was "easy" for me to do.
I've seen layers of ply screwerd together and then cut at one angle so there's no "steps" like mine. Would could be a better idea?
I have the same problem. I use the car ramp approach too. Back the rear of the truck onto the ramps to dip the trailer then a small plank that sits under the trailer ramps that the front wheels lift up on before the main ramp to help the nose clear.
    • Kinkstah, no, coilovers aren't illegal, especially as a bolt straight in. The illegal part will be if they're altering suspension geometry beyond factory limits, or the ride height is not legal.   Sounds like the blue slipper just didn't want to deal with any later possibility of mods appearing on the car.
    • The problem has always been that coilovers are able to be adjusted, almost at any time, to be too low. Most people who ever get/got defected for/with coilovers were actually afoul of the minimum ride height rule. So the interpretation by cops/inspectors was always that it is pointless to allow numpty to raise his coilovers and get the car inspected/cleared, then just drop them back down again as soon as they get around the corner from the inspection station.  This led to the interpretation that they were illegal unless rendered such that they can't be adjusted (ie, collars welded to the body, that sort of thing). That may or may not have ever actually been the official line, but I'm pretty sure it's not considered to be a solution these days. Coilovers themselves fall under clause 3.2 b of that manual, because they are an "installation of a variable ride height system" and they don't fit the exclusions in that clause (which point to air springs and other pneumatic adjusters). So, as per previous statements, they require engineering cert to be legal on the road. Once you have such cert, provided you do not adjust them outside the height range covered by the cert, you are OK. Without, you have an unroadworthy vehicle.
    • Here E10 is the cheapest fuel. And general advice is to not use it unless you hate your car. From what I remember it clogs up stuff in the fuel system or injectors?  With US/Canada being E10 across the board, does that mean that all fuel there is terrible?
    • Sorry, are coilovers ACTUALLY ILLEGAL in NSW? They aren't in Vic, as long as they retain 70% of stock travel and the car is above 100mm off the ground. Does NSW actually have a law making coilovers actually illegal? RWC/Blue Slip/Engineering people not knowing the actual f**king laws boils my blood. Demand them to point to the documentation that states a coilover is illegal. (it may exist in NSW ) Edit: I checked. They aren't. https://www.nsw.gov.au/sites/default/files/2021-02/RMS-infosheet-light-vehicle-modifications-manual-suspension-and-ride-height.pdf
