Loading up a track car
i have a 33gtst i use as my track car (pic below)
The car trailer i have makes it hard to load up as the ramps are to short and the front lip of my car hits when loading...
Its not as easy to put longer ramps on due to the design of the car trailer and how they are stored.
I dont want to make the car higher etc and im sick of putting my shit bumper on to load up
any ideas....? would finding a pair of 20s and chucking on some cheap tyres with a huge tyre profile lift it enough to get it on? finding 20s for a skyline could be tough that fit over evo brembos also
Any other ideas!?
https://www.sau.com.au/forums/topic/471151-loading-up-a-track-car/
A lot of people I've seen just remove the front bar in this situation, using Dzus fasteners or similar to make it quick and easy.
Otherwise, could try carrying blocks of wood around to help at the start of the ramp.
I feel like 20's with high profile will certainly have massive clearance/rubbing issues
I've got timber for my driveway. You have to reinforce it where it is lowest, and shave the ends so they sit flush against the two ends but they work well. And cost a grand total of $14 and one hour.
I should add we also used them for loading and unloading my car onto a trailer. Exactly as described above.
the easiest way to improve both the angle of the ground to ramps and ramps to bed of the trailer (where sometimes zorst scrapes) is to raise the rear of the tow car on caravan leveller/ramps or similar.  I've seen the same trick with a jack under the towball but I think that puts a hell of a lot of weight on a jack...
And if that's not enough go the blocks of wood suggested above at the start of the ramp, you can even have them flat on the ground as long as they are lower than the distance of splitter to ground on the car.
And if you can work out how to do it, long ramps are the real answer.  About twice what a normal trailer allows for is lovely.
  • Like 2
My car has a splitter on it and removing and re-attaching is a pain, I made 2 stage ramps with some handles from pine sleepers. They just sit on the trailer behind/in front of the car and are held on with tie downs.
Ghetto as but works and was cheap.
I could only find these 2 photos quickly and added one of the Silvia to show the splitter height. GTR clears it too.
The length was determined by how long needed to hit wheel before splitter edge hits timber.
I also have some of those little plastic Cusco ones that allow you to get just enough height to get a jack under it which is enough for people.
  • Like 1
I'd like to make a V2 that's lighter or I did consider running a drill through them to take core sections out but was worried about them cracking and splitting.
I am not a great builder/fabricator and have limited power tools so this was "easy" for me to do.
I've seen layers of ply screwerd together and then cut at one angle so there's no "steps" like mine. Would could be a better idea?
I have the same problem. I use the car ramp approach too. Back the rear of the truck onto the ramps to dip the trailer then a small plank that sits under the trailer ramps that the front wheels lift up on before the main ramp to help the nose clear.
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
    • Murphy strikes again! Nothing at all would have gone wrong if you had the tool kit in the car! You'd have just found the clamp loose the next time you went to touch it...
    • I have been being VERY quiet about what you're alluding to, as it is something that ticks me off... The number of cars from factory that run coil overs is HUGE! Most of them these days do... The other part that annoys me, is people saying "Well all the incabin adjustable suspension is illegal by blah blah blah"... If that's the case, then why can I buy a car brand new that can do it if, FULL STOP in cabin adjustable suspension is illegal...   Also, I could just chuck some aftermarket shocks in my car, throw the stock springs on, after my blue slip, dump my super low springs back in. Same shock and spring style setup... Hell, they could also be the same colour springs etc.     I'm voting, BlueSlipper didn't want to touch the above car for some reason. Whether it be some sort of bias against the car, the owner, them maybe having previously done dodgy shit and now they're being super careful in case they get slapped in the face by the Gumbyment again... Find a new blueslip place.   And can confirm as you had said, yes there are holy bibles of vehicle heights, and all sorts of other suspension stuff. Heck your run of the mill mechanic, and tyre shop has access to all of that stuff. It's how they do wheel alignments...
    • Funny story Heading to Sydney this morning on the HWY there was some slow traffic, so I gave it the beans and midway through my overtaking "power run" I lost all power It seems that I missed a hose clamp,  and the MAF and filter went WiFi To make this more problematic, the little tool kit that lives in the boot, is sitting in the sun room at Goulburn......LOL Luckily for me I found a bit of steel on the side of the road that could be used like a rusty and bent flat head screw driver to tighten it up enough that it got me into Sydney, it is now all tight like a tiger with the aid of a 8mm socket Note to self: Use my brain and double check stuff, and always keep that little tool kit in the car for when I have a brain fart
