Loading up a track car
i have a 33gtst i use as my track car (pic below)
The car trailer i have makes it hard to load up as the ramps are to short and the front lip of my car hits when loading...
Its not as easy to put longer ramps on due to the design of the car trailer and how they are stored.
I dont want to make the car higher etc and im sick of putting my shit bumper on to load up
any ideas....? would finding a pair of 20s and chucking on some cheap tyres with a huge tyre profile lift it enough to get it on? finding 20s for a skyline could be tough that fit over evo brembos also
Any other ideas!?
https://www.sau.com.au/forums/topic/471151-loading-up-a-track-car/
A lot of people I've seen just remove the front bar in this situation, using Dzus fasteners or similar to make it quick and easy.
Otherwise, could try carrying blocks of wood around to help at the start of the ramp.
I feel like 20's with high profile will certainly have massive clearance/rubbing issues
I've got timber for my driveway. You have to reinforce it where it is lowest, and shave the ends so they sit flush against the two ends but they work well. And cost a grand total of $14 and one hour.
I should add we also used them for loading and unloading my car onto a trailer. Exactly as described above.
the easiest way to improve both the angle of the ground to ramps and ramps to bed of the trailer (where sometimes zorst scrapes) is to raise the rear of the tow car on caravan leveller/ramps or similar.  I've seen the same trick with a jack under the towball but I think that puts a hell of a lot of weight on a jack...
And if that's not enough go the blocks of wood suggested above at the start of the ramp, you can even have them flat on the ground as long as they are lower than the distance of splitter to ground on the car.
And if you can work out how to do it, long ramps are the real answer.  About twice what a normal trailer allows for is lovely.
  • Like 2
My car has a splitter on it and removing and re-attaching is a pain, I made 2 stage ramps with some handles from pine sleepers. They just sit on the trailer behind/in front of the car and are held on with tie downs.
Ghetto as but works and was cheap.
I could only find these 2 photos quickly and added one of the Silvia to show the splitter height. GTR clears it too.
The length was determined by how long needed to hit wheel before splitter edge hits timber.
I also have some of those little plastic Cusco ones that allow you to get just enough height to get a jack under it which is enough for people.
  • Like 1
I'd like to make a V2 that's lighter or I did consider running a drill through them to take core sections out but was worried about them cracking and splitting.
I am not a great builder/fabricator and have limited power tools so this was "easy" for me to do.
I've seen layers of ply screwerd together and then cut at one angle so there's no "steps" like mine. Would could be a better idea?
I have the same problem. I use the car ramp approach too. Back the rear of the truck onto the ramps to dip the trailer then a small plank that sits under the trailer ramps that the front wheels lift up on before the main ramp to help the nose clear.
    • But seriously, can we ask for the results of the "tip a bottle of metho into a nearly empty tank" experiment?
    • Hang on. Let me get this straight. The desire is to have coilovers, BC in particular, to be MORE comfortable on Sydney roads than stock suspension? Well, that's obviously not right. BCs have crude damping design at the very best, and typically hard spring rates. BC stands for Billy Cart. And then, the desire is to put in some shitty old worn out stockers, to get it blue slipped and then put the BCs back in? And then.....what? Not worry about getting pulled up by the Plod? Because you seem to have raised a worry about paying for engineering (which actually does solve all your legality problems) and still getting pulled up.... but the only problem there is that if/when that happens you have to show your paperwork at the inspection station. Whereas, if you just swap in borrowed shitty old stockers to get it slipped now, and then you get defected in the future, you have to go find more shitty old stockers then too. You course of action looks like this set of options: Buy brand new stock type dampers, and springs. probably cost a bit more than $1k all up, but will last for the remaining life of the car. Put them in, pass inspection, drive on them forever more. Hell, they could even be really nice Bilsteins and Kings or other lower&stiffer springs if you wanted. Get the car engineered as is. ~$1k. Buy new Shockworks coilvers (or MCA) and also pay for engineering. You're spending a lot more here. But these will be the best things that you could drive around on.
    • Might be worthwhile hitting up Facebook's groups, I know most of them contain terrible people and scammers - however you might be able to find someone that's in Sydney with factory suspension you could purchase and/or hire. Just do not send any form of money anywhere, in person cash only.
    • Thanks @Duncan Ride height is fine. I think it's almost stock tbh. Happy to share a pic. I don't actually have a regular mechanic as haven't lived in Sydney too long. Could you or anyone recommend any shops in Sydney?
