Took it to work and hot washed the majority of parts. Honed all the bores and deburred number 6 as that had piston melted to the wall. They all came out good but there is slight imperfection on 6 so I will be taking to to my machinist to get it sorted out.
No metal went through the oiling system so all bearings and journals are good to go.
I dodged a bullet here I reckon.
Yup, love that piston! Bore might be alright- fingers crossed.
Nick at Allstar in malaga might be able to tune a Link... worth looking into seeing as a few people have had success with them. Certainly cheaper than haltech. Or go the emanage route?
  • Like 1
Hey mate, awesome post, great job on it all. How did you lean it out if you had the gfb g-force 3 with Wideband integration? Was it not set up or did it just not do what it was meant to do? Cheers man and I admire your commitment to press on, I woulda wiped my ass with it by now ?
I hadn't got around to welding in another bung or buying a sensor.
I was going off what Hobdrive was reading from the factory sensor which according to it, it never went lean. The sample rate must be too slow though.
Overboost function was set up but it didn't work. Maybe it needs a bigger range than .5psi to react quick enough.
Edited by Sack87
Yeah I’m going down the same path (gfb g-force 3 and innovate lc2) as I’ve got an intense billet rs ready to go on. I’ve read overboost function needs to be set 10%higher than target boost, so maybe not enough reaction time hey!! Anyway, good job and I’m excited to see how you get on with it in the future.
New motor is getting, EMU tune, bigger pump, bigger injectors and the wideband setup. Hopefully safer and with more to boot.
  • Like 1
On 25/11/2018 at 7:34 PM, Sack87 said:
Built both heads up today. Only put Supertech valve stem seals in and OEM for the rest as there are no aftermarket springs or valves available for these.
I now have a 4 week delay on rod bearings from Japan so that's pretty much all I can do until the new year.
Did you go oem rod bearings? What was the reason you didn’t go acl for these also?
You can only get OEM bearings for these. ACL and King Bearings are wrong, full stop.
Do not believe anybody who has a listing as fitting VQ25DET, as they don't.
Cheers for the heads up. Does the same apply for the mains? Oem only? What are you doing about piston and rings number 6? Do you have to replace in a complete set? I’ve read this thread about 20 times haha, so glad I’ve stumbled onto it. Also how good Is Nissan epc/amayama [emoji106]
38 minutes ago, sta934 said:
Cheers for the heads up. Does the same apply for the mains? Oem only? What are you doing about piston and rings number 6? Do you have to replace in a complete set? I’ve read this thread about 20 times haha, so glad I’ve stumbled onto it. Also how good Is Nissan epc/amayama emoji106.png
Yeah same for mains.
You can buy single pistons from Nissan, which I did to replace number 6 and bought another set of rings. All the bores got honed so it's fresh again.
They're both headache savers but Amamaya's processing time is a bit slow. Everything is in Australia for this order yet it takes 3 weeks to get it.
  • Like 1
  • 4 weeks later...
Hey Brendon (spelt your name right this time as I'm on my computer not the stupid autocorrecting phone!), I'm organising parts to do some preventative maintenance on my spare engine and am looking at valve stem seals...
Partsouk has oem for 4.72 (& 4.26 on amayama) each,  and I was also looking at Supertechs. Where did you get your supertechs from and are they the same as rb25det or similar?
Have your parts come in yet? Cheers, Andy
Edited by andynogo
Supertech end up cheaper than stock and they're better.
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com.au%2Fulk%2Fitm%2F272798735032
Amayama and Partsouq have no rod bolts so you have to pay 3x as much to get them from Melbourne. In saying that though, I got them overnight instead of 3 weeks
Thanks for that. Set ordered.
So, I got the motor pretty much buttoned up on the weekend. Got screwed around with rods bolts not being available for two suppliers and ended up paying 3x as much to get them from over east.
EMU was purchased and I just finished sorting out it's harness tonight. Deutsch plugged it so it can be removed easily if needed and labelled all the wires relevant to run. Still need to do the engine harness to match now.
Got a Kinugawa dual port gate coming, innovate LC2 wideband, silicone coolant hoses, new catch can to modify and a fuel pump. Need to buy injectors, new coil packs, plugs, Greddy MAP sensor and looking at possibly getting a stall as well.
  • Like 2
23 minutes ago, andynogo said:
Looking good. Will be very interested to see how the emanage goes- was thinking of that for mine. Who's going to tune it?
Using the tune Matt has online and C-Red to clean it up. No one else will really touch the EMU
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
    • Its a well known brand in New Zealand; its a rebrand of the Rhino RAV3.  I don't know what the wiring difference *is* between the rev.1 (installed about 15 years ago) and rev.2; but as you say I would think its reasonable that it uses the same immobiliser relay circuits. I had a look but couldnt see a similar harness; but didnt move things around since I didnt want to mess with it   It was one of AVS well known Authorised Installers; I spoke to AVS themselves about it but theyre unsure hence seeking advice more so from the skyline community who are more familiar with the actual car and its wiring. Im in Auckland; but the installer is on the other side of the city so hes very reluctant to come back to even look at it to confirm something isnt connected into the wrong wire.  I dont want to drop the name since they *did* do a really good job for the most part. Everything is very tidy and he fully replaced all the alarm wiring, all the sensors, the wiring to the door motors, installed a switch which was never installed in the first place...really happy with the alarm install itself..just not this one issue. We all make mistakes, if it is the alarm, I just want my fuel pump getting proper switched, fused, power as it was; without having to shell out for an auto electrician to switch a wire and tell me it was the alarm.
    • Even with the piston at TDC there was room for it to drop, but I don't think it can drop fully into the cylinder, the problem you have is that you need something pushing against the valve to hold it up so you have enough room to put the new stem seal on and the spring etc.  I used compressed air only because putting rope in the cylinder seemed a bit risky to me, I know people have done it countless times before like this. Overall it's a pain in the ass job. Honestly you'd probably be better off taking the head off because the risk of dropping something in the engine and the finicky-ness of it all is very stressful. If you are going to attempt it though i 10000% recommend a 36050 valve spring/keeper tool. I had both the traditional lever type and after doing 1 cylinder it was absolute pain to get those valve keepers in place, even with 2 people. That 36050 is amazing, you do have to push hard to get them in place but it works perfectly almost every time. Back to my actual issue I think my engine is just tired and old and the rings have gone bad. The comp numbers (cold, no oil) were: Cyl 1 -129psi Cyl 2 - 133psi Cyl 3 - 138psi Cyl 4 - 137psi Cyl 5 - 157psi Cyl 6 - 142psi   Cylinder 5 and 6 having the most carbon on them.
    • Who did you have do the installation? I actually know someone who is VERY familiar with the AVS gear. The main point of contact though would be your installer.   Where are you based in NZ?
