Which should I go with GTX2863, 2530, or 2860-5
Before I have my r32 tuned on a haltech, I want to install new turbos. My goal is 600-650hp. Currently making 530hp on R34N1 turbos. Cant decide between gtx2863,2530 or 2860-5.
Current setup
530@19psi
2.8l (supposedly tomei stroker)
tomei cams
tomei manifolds
nismo intake manifold
700cc injectors
nismo fpr/pump
N1 oil pump and water pump
R34 N1 (AA403) turbos
hpi elbows
mines frontpipe
Decat
HKS exhaust
tomei ecu
Ever looked into a modern twin scroll single turbo?
You'll get your power goal with ease and be given an excellent power band along with fantastic transient response.
  • Like 1
I'm making around 290 awkw on GT-SS.
Putting in a set of newly rebuilt HKS 2510 with GTX2863 compressor wheels (not the whole CHRA) this week. I.E, they end up being a 2510 turbine, turbine housing, compressor housing with the GTX wheel.
Will report back in the Dyno thread by the end of the week if i wasted my money or not :-)
What power are you shooting for with that setup?
Hoping for your generic -5 power on a standard unbuilt 26 with pump fuel. I.E 340 -350 awkw on around 22 psi. In theory i should have similar to -9 response with -5 power.
Depends on how healthy my motor is, and final tune..
Edited by djvoodoo
upload pic
  • Like 1
3 minutes ago, GT-R David said:
I think this is what almost everyone wants.
Im looking forward to see the results.
Too good to be true :-) Well, we should find out by Friday. I've read the whole GTX thread, and most people are using the 2863 CHRA with mixed results. This turbo is not the same, so a little unsure how they will react on my setup.
Motor health for me will determine how aggressive final tune can be. I've had a few dud tunes over the past 4 years so trying to be on the cautious side.
Check out what@ActionDan has achieved with -9s in his build thread:
https://www.sau.com.au/forums/topic/460737-z-tune-inspired-r34-project/?do=findComment&comment=7839063
It is food for thought on what is possible with a reasonably standard looking engine bay (if that is what you want / need).
[quote I.E 340 -350 awkw on around 22 psi. In theory i should have similar to -9 response with -5 power.
I've got this [emoji16] but it's achieved through a 26/30 build with -5 turbos, amazing response and making 360awkw on 22psi.
And at roll racing the other night, wasn't much that could hold me through 2nd and third gear
This is the mystery engine that somehow made 395rwkw on N1s?
I'm using a bigger set of turbos and E85 and only managed 380rwkw, which I thought was considered decent for -9s. That's with N1 manifolds, good intercooler, big dumps, big exhaust etc.
The only way you're going to retain N1/-7/-9 like response and make a minimum 447rwkw/600rwhp is to go full twin scroll (twin gates) single and most likely e85 and bump up the capacity decently.
200cc of extra capacity is not going to change the lag considerably.
What dyno did the car make the 530rwhp on? Or is that 530 calculated engine HP?
You can reach 600 rw murican HP a lot easier than you can Australian HP.
Our dynos seem to read very differently.
If we ignore the numbers and just say you want to make 15-20% more power to the wheels at minimum (530 -> 600/650) and you can currently do 530 on N1s, any of those turbo combos will get you there, but the car will not be as responsive.
You can look at putting better ramp rate/lift cams in as the Tomei are known for being a little soft, ramp especially. With cam gear adjustments you will "almost" match the response but with substantially more grunt up to.
Otherwise, more cubes and full spec TS setup :)
Edited by ActionDan
  • Like 1
2 minutes ago, Trailmix said:
It was on a dynocom 5000FX, which is a AWD Dyno. Though all the pulls where made in RWD. You can see the engine HP/TQ at the bottom of the graph. 609hp /453tq
I think what most people here are trying to say is R34 N1 (or -7) turbo's do not flow enough to make 400rwkw, even with a 2.8l. They are a 500ps range turbo.
No matter the difference in dynos. My turbos are not that responsive low end like a -7 should be not seeing full boost until 5500 range. The gtx2860/2863 should spool up around the same, as my current setup?
Edited by Trailmix
No idea because lots of what you say is contradictory?
N1s basically ARE -7s so if they are magically not that responsive yet make 530rwhp, then maybe they are not N1s?
You will also LOSE response from having bigger cams, if you're not compensating with gear adjustments, timing changes etc.
Post some dyno graphs with RPM and Boost.
I think you need to work out what you actually have first.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
