I didn't say it was the cheapest solution, I said "Low mount twins are fine for sub 400rwkw and not costing the earth or having mad lag. "
Which is true.
Wouldn't expect a basic T3 .82 single scroll to be markedly different in response or power but with the added issue of potential defect.
You guys pull your dicks like using 2 turbos is the end of the world and the reality for plenty of people doing is that they are fine/good enough.
Are there better ways of doing things? Of course, that's true for any solution - there's always something better.
Do they work and product a result? I can say personally yes and the result is decent enough.
For THIS application, given his power/response goal he should go full spec TS single, i think we can all agree on that.
Unsubscribing from this thread now. Looking forward to seeing resultts in the dyno thread.
  • Like 1
Yeah you only hear about the single turbo builds where people go all out and get an EFR and TS manifold and then buy a stroker kit while they're at it because well you've gone this far....
half decent manifolds are cheap and so are medium sized turbos
  • Like 1
Didnt Usmair slap one on his stocker GT-R? Looked like it performed well just the numbers were a bit of a croc. That dyno needs to be recalibrated by Mainline.
Went well...But he couldn't run 35psi? ?
On 11/16/2017 at 2:21 PM, discopotato03 said:
Just for my 2c .
Personally I would never use these GTX compressor wheels without a port shrouded compressor housing , I can't remember too many if any being supplied complete by Garrett without them .
RB26 twins don't appear to be an application that can use port shrouded compressor housings because there wouldn't be space for them .
I think there are good reasons why Garrett supply RB26 replacement turbos with conventional style compressor wheels , mainly compressor surge .
A .
GCG has you covered.
https://gcg.com.au/petrol-performance/performance-4/turbochargers-kits/nissan-rb26dett-bolt-on-turbo-set-gtx28r-series-detail
Still not to take away from any of the other issues but if you absolutely must have 500awkw with stock housings you're probably not going to get better than that.
I emailed GCG about putting 0.63 rear housings on these. This was their response:
Thanks for the enquiry. We can supply these with an 0.64a/r, which would definitely bring them on earlier, although our testing did show the test vehicle surging under light throttle. However, we haven’t tested these with the new surge slotting on the compressor housings, so it’s something that could possibly work, as long as the engine is capable of handling the airflow that the turbochargers provide.
The issue we had originally is the GTX turbochargers push a HEAP of air into the cylinders, but the engine just could not handle the excessive flow, and this is where surge occurred. If the cylinder head is modified is the right way, and you have a nice big volume plenum, the issue shouldn’t present itself. Keep in mind we cannot guarantee they will not surge.
You also need a big BOV if you’re planning on running these (Turbosmart Race Port 50mm should do the job)
Aren't they referring to the intake rather than exhaust? Sounds like they could work well, you just can't oversize the turbo for the engine else end up with flow issues.
  • 3 weeks later...
I bought a new billet wheel 6 + 6. It is 5mm higher than usual. They weigh 47g (old 6 + 6 weigh 50g, 11+0 weigh 56g). I'll try them. The wheels of the GTX series are clearly not suitable for rb26.
Edited by frakzz
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
