I've been wondering guys, how much would mt GTR be worth in australia?
123000km on the clock, decent paint, paint looks nice but not the best quality, the entire interior is there but both seats have a small rip on the bolsters nearest to the door and it shows its age (wear and tear on the leather parts) Full adjustable coilovers, 18'rims, nicely rolled fenders (looks really good). Rest is 100% stock.
How is this relevant to the topic? Make a new thread. Also, look at other cars that are selling that are close to your spec. Shouldn't be hard to see what the market is paying for them.
More than you can afford pal.
R32 GTR.
  • Like 2
R32 GTR.
Well yeah, since I alteady spend my cash buying one :P
Bruh, we've been talking bout moosepower and canadian domestic market air before and you think that was on topic?
Things aside, I'm being real impatient getting my sky back so I'm rummaging through the forums to keep busy when I'm not working.
  • Like 2
$15-$25k
Maybe more with the "external BOV" ;)
Well f**k.
I called the tuner this morning to have some more news. His dyno is ready and everything is set for a dyno run... Except the GTR.
The oil pressure is low af. So low that the oil pressure light sometime comes on when it's idling. He doesn't want to dyno it in that state.
He's currently investigating to what causes said issue. I'm afraid I have a messed up oil pump and will need to get it replaced. Could possibly explain the oil leak I have. Should have some more news coming.
6 hours ago, drunken0elf said:
Well f**k.
Got a bit of better news.
He's quite busy so only had time to rapidly check the car. The odds that it's the oil pump are low. The oil leak is probably from the powersteering pump or something connected to it (gasket,seal or whatever) and the crappy oil pressure is probably due to the old ass sensors acting up.
Waiting for him to get a more in depth look. Guess it's gonna sit there another 3 weeks lol. :P
Oh well. Much rather not drive my car for 2 months then risk blowing up the engine because of a faulty oil pump.
Edited by drunken0elf
  • Like 1
the oil pressure sender is known to go bad, luckily it is an inexpensive fix, same unit as 300ZX and should be readily available at local auto parts store.  so try that first before jumping to the conclusion that oil pump is bad.
1 hour ago, GTSBoy said:
Yes....but the oil pressure switch is a separate thing, yes?.  So for them both to indicate low pressure is not the best news.
Exactly why he wants to investigate. He's quite good with electronics, so I'm guessing he's going to test the voltage and wiring.
57 minutes ago, Hadouken said:
Put a oil pressure gauge on it and know for certain
Probably will be part of the solution, but it's the darn oil pressure switch that bothers. Does it switch on because it's based of the pressure reading from the other sensor or does it have a reading of it's own?
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
