Target 400 RWKW RB25 DET Torque Plate?
Hi,
I've done some searching and couldn't find a response, sorry if it does exist or if this has been discussed already. I'm building an engine currently for my time attack car. I'm a control freak and want to manage all of the build that i possibly can. However I am not a machine shop so don't have that gear. I've got a machine shop lined up and intend to have my block torque plate machined. Meaning that the rings should also be gaped with a torque plate. So I should provide them with the rings etc and have them gaped. My problem with that is I cannot then check those without the torque plate at home. Now I've just had a light bulb moment... Why not bolt the head on and gap the ring from the underside as I'll have the bare block on a stand. Am I missing something? Is there any reason I cannot do this? Am I an idiot for thinking this is a good idea? Any engine builders or experienced guys want to poke holes in it? I can think of some small negatives but nothing drastic really, just having to reach further in with the feeler gauges, might be harder to square them while deeper in and poor light really. apart from that... I can't see why not? Admin sorry if I'm in the wrong topic, seemed to be the best one.
8 hours ago, GTSBoy said:
You can do it that way.  But given how often your machinist probably needs his RB torque plate, you could probably just borrow it for a week.
That would be idea, but I've never used these guys before, don't know if they'd be down with that. I know if I was them I wouldn't load one out, different story for a long time customer or someone you know personally.
Whats a 400kw torque plate?
I dont build engines or machine things. Are there different kinds of torque plates for different power applications? Just curious thats all.
Edited by Cyko34
34 minutes ago, GTSBoy said:
He's just advising that his target for the engine is 400kW and that is supposed to provide background on how important the idea of using the torque plate when doing the rings is.
Correct, just emphasizing the fact it will need to be right, if I was just slamming together a fresh stockie I wouldn't both with any toque plate at all, let along using one while trying to gap the rings. But for this I am going to a great deal of time and effort to make the engine as efficient, safe and powerful as I can within reason and for my goals.
If  you are going to use them for the machining you could give them a cash deposit.
To just say that a torque plate is required to adequately measure ring gap is not necessarily the best way to approach this issue you are spending an excessive amount of time investigating. There are so many other factors that require consideration. Fuel used? Target rpm? Target boost? Target CR? Combustion chamber and piston crown design? Engine block prep? Parent bore or Ductile iron sleeve? Piston to bore clearances used? The list just goes on and on. If you are so hung up on a torque plate and making sure the deck is square and bore is true, measure it all and make a decision from there. If this is all a bit much for just working out ring gaps, get it to an experienced builder.
Yeah, another good idea, I'll see how I go, but also good to have the backup plan, no-one can poke a hole in the upside down access whit the head bolted on yet, so I know I can do it if needed. Cheers.
Hi,
One thing you are forgetting is that there will ( should ) be a mains girdle in place when the block is bored/honed and this should be in place also when setting the ring gaps with the torque plate on.You will find it pretty difficult with the mains girdle in place to get in there from underneath...
Jason
Jason
No not forgetting the mains being bolted up, yep will be a pain in the arse, but has been considered. If i decide to do it this way I'll let everyone know how much of a pain it is and If i think it's worth it lol.
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
