4 minutes ago, WantGTR said:
you bastards lol, i was 50/50 about this, knowing full well about the possible scenarios if i didnt upgrade. in anycase, RHDJapan will be getting yet another order from me.
Haha good man! ?
The added expense now will save you later on mate. ?
im running a similar setup to this.
Taarks surge tank with twin walbro 460 pumps staged ( DON'T RUN BOTH PUMPS FULLTIME )
255 walbro in tank.
turbosmart 1200 fpr
aeroflow big filter to rail
twin feed plasmaman rail
using only hardline due to the corrosive nature of e85, 2x  y blocks. oneway valve on the staged pump. running factory  fuel lines
  • Like 2
^^Nice.
Hows the stock alternator holding up lol?
i was considering the Taarks one. i think that surge is a tiny bit bigger than the raceworks. raceworks was a touch cheaper but didnt come with fittings so they are probably the same price. 6 of 1 half a dozen of the other i guess.
Yes pumps will be staged.
There is teflon lined hose which is rated for e85, that is what ill be using. i do like hard lines but ill end up making the bends all wonky and thats not gonna look good lol.
havent tested it yet  as im waiting for my turbo and ecu.
but am using power cables from a falcon or territory  and earth strap can pickup from wreakers for like $20. i think the alt will hang in there. hahhaha also running elec fans
  • Like 1
8 hours ago, bilk06169 said:
I like that a lot.  I'd be finding a way to put nylon or similar brace blocks between those lines to clamp them together, and then brace at least a couple of the longer ones to something rigid to prevent them from vibrating until they crack.  It will happen eventually on those ones on the surge tank.  Brace them out near the bends and avoid the E85 shower.
  • Like 1
I don't like the idea of staged pumps, especially with ethanol. Seen enough he said/she said where the 2nd pump giving up prematurely. Also, if your regulator isn't up to task you will get a spike in pressure when the 2nd pump kicks in.
Having said that, I also don't like the idea of running both pumps full time due to heat.
For these reasons, I run both my pumps (edit: not sequentially, derr) in parallel via a 100amp solid state relay, off PWM from the ecu (G4+). It works fantastically.
Edited by MagicMikeZ32
  • Like 1
Bilk, you're running twin walbro 460's down a stock hardline using the quick connect fittings at the tank hat?
the internal diameter of the hardline is probably only 6.5mm.
that sounds extremely restrictive to me
also, the only time I'd use staged pumps is with a fuel pressure sensor with an ECU that did injector delta pressure correction and a cutout function if it got too low.
I've got a bit of a frankenstein setup, running the following
holley boostapump runs normal voltage on 98 fuel, switches to 17.5v under boost when ethanol >10%
continental FPCM pump controller (from range rover/aston martin) takes a 100hz pwm control signal from ecu and produces a 20khz pwm pump driver
Pierburg L3LM screw pump (flows 430lph at 80psi - 17.5v)
powerhouse racing fuel tank hat with speedflow -8 supply and -6 return
Sard Jet Pump for saddle tank (much higher flow capacity to stock one)
dual holley hydramats in the tank, with magnets holding to floor, one is 15x3" straight (located where stock sock goes) and a 15x8" cross located in drivers side saddle. this covers most of the drivers side saddle floor.
rail return splits and flows back onto both hydramats to keep them wet. I am HOPING this totally eliminates needing a surge setup, looks totally stock, pump is quieter than the nismo due to being a screw instead of a vane and will do 500awkw, but we shall see!
Edited by burn4005
with 6an supply to the surge and as well as a 8an return to the surge surely that would be enough to keep the surge full?
best part is his stock fuel gauge will work with that fuel hat.
your fuel system seems to have a lot going on, what was the reason you didnt want a surge?
Twin intank pumps using the Frenchy's kit are the way to go for any kind of street car
Not cheap but by the time you do a proper surge tank setup you'd be coming off with a similar cost... and a setup in your boot.
  • Like 2
I was considering the frencys setup but it was significantly dearer than the raceworks surge and youre doing all new lines anyway.
Mounting a surge is a bit annoying but dont really care about losing a corner in the boot as its not an everyday car.
Am a fan of the frenchy setup though.
1 hour ago, sneakey pete said:
I guess with raceworks you'd be up around 900 bucks instead of 1250 or so wouldn't you, so a little cheaper I suppose?
according to kudos 1805+post or am i missing something?
50 minutes ago, MagicMikeZ32 said:
The raceworks one looks cheap
it can look how it wants if it does the job what difference does it make? or should i have splashed out and bought a Radium or AI for the likes/follows?
Didn't realise you had purchased already. Agree it can look how it looks as long as it does the job. For me if I was going it, I'd pay the little extra for the nice stuff :) I don't have anything against raceworks, I use a shitheap of their fittings and lines in my car. Something as prominent as a surge tank in the boots tho... ;)
Thought i might add this here as its sort of relevant, picked up the bypass idea here too for the flex sensor so thanks guys.
I wont be using a surge tank as my car is street only so dont think ill need it.
Im using a walbro 460, i may need to run a second pump and when the time comes it will be mounted intank as well.
Using the standard hat with bulk head fittings for the cable and will be putting in a dash 8 fitting through the lid and new line up to the rail, ill put a T piece in the back of the fuel reg and run one to the flex sensor and back to the standard return line and the other will be returned to the tank using the factory feed line. Hope i have explained ok as it is usually lost in translation from brain to mouth, or finger in this case.
I hope it will make everything work and i have not overlooked anything.
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
