Ok so I've come to the conclusion that there's no way I can get to this hose. I've decided I'll run another hose to bypass this one, should be much easier than trying to replace this one! >.<
Hi bro.... gee ya gunna hate it as i know its a prick... its a steel pipe section that runs behind the head yeah? It comes in a whole section with 2 pipes.. there is a nut in the center!!
That hose is a prick to replace [emoji21] i just replaced mine while i had the head off so it was super easy [emoji5] i actually replaced that entire metal coolant line and the rubber hose section with a braided line which can be purchased from most autobarn stores [emoji106]
Ok so I couldn’t find anywhere on a public holiday to get braided hose. Instead, I did find the perfect shaped heater hose for my application! Funnily enough, the hose I used was for the intake manifold of a 1992-1996 Magna. Go figure.
So, as mentioned in my second post, I’ve opted to completely bypass the original route for this hose. I’ve now run a length of hose from the original source at the back of the intake manifold, down the back of the head neatly tucked away, and I then used rotary tool to cut the hard coolant line to the turbo, slip on the new hose and clamped her up.
Pictures speak a thousand words. Might not be the ideal solution but it’ll work for me ?
After posting, I realised one of the pictures I uploaded was of those hose way in the air when I was fiddling around with placement - it didn’t stay at the top of the bay! :P I was able to route it down behind the head :)
4 minutes ago, Ben C34 said:
Did you flare the hard line where you cut it? If not solid chance it will leak
No sir, although I definitely should have! As this is a temporary solution I’ve opted to put a few layers of stretched silicon tape on the end, on which I slid the hose on and it was super tight and only went on with a little bit of rubber grease. I then clamped  her down good. I totally acknowledge this isn’t great long term and I’ll aim to sort out something more permanent when I next have a decent play under the bonnet.
4 minutes ago, admS15 said:
Good thinking, might be a good idea to wrap the end near the dump pipe with some sort of heat proof material or make a heat shield emoji106.png
Cheers - yeah that’s smart I might see what I can dig up
fuuarkk.. fun times :(
I've had that split on my current car (old motor) ended up replacing it with EFI hose and ran a braided china-spec ling long dim line to the turbo.
New motor has proper 4-ply eBay silicon hose to the braided water line lololol...
Someone come swap me their BMW 335i for my entire car/motor
  • 1 month later...
Same here I used a piece of good quality EFI hose .
For the record I would have used a couple of OE quality EFI hose clamps as well .
You can get at the mongrel on an R33 by removing the three bolt IAC housing and some of the wiring loom brackets in that area .
A .
  • Like 1
A bit late, but I replaced that hose on the Stagea (RB25DET NEO) the other week. Prick a job to get out, I used really long nose pliers and long nose bent pliers. To get to the clamp behind the engine I went horizontally from the intake side. I replaced the hose with Gates 8mm universal Z bend from Repco and new clamps.
I bought a seven piece radiator hose kit on Ebay, trying to workout where all these hoses go :/
  • Like 1
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
