2 hours ago, AngryRB said:
Where do xspurt injectors sit amoungst the modified injectors?
I have had the 1000's on both the Rb25 and now 3025neo and in both motors when cruising there a slight stutter/jerk happening, worse when engines cold. 2 tuners have played with it and point toward the injector size or the power fc being an old model.  It would make sense if the atomisation was crap at light throttle, would E85 help the atomisation or cause more issue ?
The tips are milled off, they even clearly state that in their listings. At least they're honest!
E85 will help because of the longer pulse widths required.  Atomisation won't really be any better, might even be a little worse (effectively) because E85 is less volatile than straight petrol.
If i was going to run the Bosch '040' 980cc injector with the extended tip in an RB26, where would i find the appropriate adapters to suit standard RB26 plenum/fuel rail?
Link to bosch motorsport website with info on the injector https://www.bosch-motorsport-shop.com.au/980cc-min-ev14-injector
https://www.efisolutions.com.au/injector-nozzle-adapter
Something like this,  sorry didnt check to see if they were the right size for rb26 but gives you somewhere to start
Some people OS are running those with the tip extending further into the inlet manifold . Been a while since I looked inside an RB26 manifold , if the standard injectors are recessed up tunnels like the Neo25s are then you could run a shorter lower hat and have the tip closer to the air stream in the manifold runners .
Those 0280 158 040 injectors are supposed to have a 30 degree spray cone but it wouldn't be real good if it was spraying all over the inside of a recessed tunnel .
The xT or extended tip EV14s are approx 13mm longer in the snout than the standard tip length ones .
In a way its a pity that the 333/334 1600 odd cc version isn't available with the extended tip . Make life easier for those that need big "3/4 adapted" length injectors .
A .
A .
I would really like to know how far in they would sit. I can't take my plenum off to see and i didnt take any pics of the injector mounting position. My mate runs these 040 injectors in his Evo 6 with hypertune inlet manifold and he runs them with the tips sitting all the way in the manifold.
Obviously unmolested EV14 series injectors atomise better at their tips than the factory injectors of the 80s/90s did . I get the feeling that small single pintle ie EV1 injectors were intended to have a narrow spray cone further back from the airstream than later designs .
The fact that the spray cones on some EV14s can be 50 odd degrees means it ain't gonna work if its sitting back in a reasonably narrow passage
If you fit extended nose EV14s in the place of standard tip EV14s it extends the tip 13mm further into the manifold .
Also for the record there is what we call a 3/4 length extended tip EV14 that is a replacement Porka 997 injector . From memory they're about 630cc/min twin spray and the part number 0280 158 123 . A bit more expensive than most off the shelf EV14s .
A .
Edited by discopotato03
Conviently a mate had a 26 runner set lying around in their shed during a BBQ this weekend, I suspect that that could be an issue: the injector hole down to the runner is a decent length, almost an inch by the look.
The delphi ones i have seem to have the actual pintle even further back than the o ring seal
So you think the extended tips would work well in the 26 manifold?
It depends really. Nissan didn't run one OEM after all, there's probably a reason for that; I'd worry you might end up spraying a lot of fuel into the bottom of the intake runner with an extended tip one. Then again it might have a different flow pattern. I think there's a lot of different variables and its really going to be hard to figure out what the best option is.
There's probably some sort of optimum flow vs spray angle vs pressure distance up the tube you want your tip plus also accounting for high revs vs lower revs. To be but figuring it out without a flow bench or CFD is probably going to be veeeeery hard.
Save me starting a new thread i'll ask in here...
Which injectors would you guys recommend keeping in mind that i want my engine bay looking as 'Standard' as possible...
Chasing up to 400rwkw's on E85...
Fits standard RB26 fuel rail without mods (and don't want to run a FPR)
Want to run that at around 80-85% duty cycle...
Edited by mr_rbman
I'm confused about that 10.5 vs 11mm thing. most injectors advertised for rb26 are 11mm i thought?
Pretty sure my delphi's are, though they're in a raceworks rail now with the 14-to-11mm reducers in it. Figure i'll just buy 11mm injectors instead of messing around with removing the reducers, or am i going to end up with 10.5mm injectors if i buy ones to fit rb26?
NZEFI offer them with either 10.5 (factory Nissan) or 11mm and 14mm top hats and with the correct Nissan "square seal" on the lower caps......even a ballast resistor delete plug.
http://www.nzefi.com/product/nissan-rb-1000ccmin-top-feed-direct-fit-fuel-injector-kit/
Currently have 11mm injectors inside the standard rail, it's tight but a little lube gets them in there no dramas...
I was told to drill originally and ruined a fuel rail so didn't wanna do that a second time round...
Edit: http://www.kudosmotorsports.com/catalog/bosch-fuel-injector-package-standard-type-nissan-skyline-rb26dett-with-factory-fuel-rail-p-1127.html
These ones look like they should suit my requirements?!?
Edited by mr_rbman
    • The fab work can be as simple as a couple of silicon hoses and clamps to the factory piping.
    • Just sounds like either way you need to do some fab work to get everything to fit, so why limit yourself at that point? If the GCG high flow option is zero effort in and out swap though I'd probably do that. It's almost certainly lowest risk, lowest cost, etc. The HKS GTIII-RS option that Kapr mentioned is laughably expensive for what it is, they charge the exact same for two turbos on the RB26 so their margins are off the charts on that thing.
    • Intake manifold is not a part of the issue. The turbo bolts to the exhaust manifold. That is easy. But close your eyes and picture the physical situation. That is a T3 flange on the manifold and a T3 flange on the turbo. As long as any new turbo has a T3 flange on the exhaust housing, that exhaust housing will bolt to the exhaust manifold. This places the exhaust housing in the same place as the stock one. But now move your mental attention a little further forward. The location of the compressor housing is set by the length of the turbo's core. The stock turbo had a long core. Let's say that it is..... 100mm long. So that would place the compressor housing 100mm forward of the exhaust housing. But a highflow, might well have a centre core that is shorter. Let's say that it is only 70mm long. Now the compressor housing will be 30mm further back in the engine bay than the stock one. This DOES move the turbo's compressor outlet backwards. It also moves the compressor's inlet backwards. You will very likely have to do some work to both the inlet and outlet piping to make everything connect again. I am not say this to make it out to be a bigger deal than it is. I am just pointing out that "bolt on" is sometimes not quite bolt on. The highflow from GCG that Murray linked above (https://gcg.com.au/turbo-charger-upgrade-skyline-gtst-2iu-xtrgts-s1.html ) uses a core that is the same length as the stock core, and so does not require this extra work. It will look very much like the stock turbo. No-one uses GTR turbos of any flavour (stock, or aftermarket) in a single turbo application on RB20/25. It's not a thing. Yes, people have been putting on GT3076, GTX3076 (and bigger and smaller versions of those) and G30s (of various sizes) onto RB20/25 since forever. But these are not "bolt on". Everything except the 4 bolts to the exhaust manifold change with these. And genuine Garretts are expensive. Non-gen, like Pulsar, etc, are cheaper, variously as good or nearly as good. But still not bolt on. No-one in the right mind would pay for an HKS turbo. Not in this modern day and age. Well, yes, the GCG highflow. You could ask HG what he can do to make the compressor housing sit in the original location. There are surely others doing highflows around the world. And some of the eBay/Temu ones (as reported by Dose) work and don't die. Bit of a lottery though. I would send your turbo to GCG (here in Oz) to be highflowed if you want a trivial no-extra-work option. But seriously, the work required to change inlet and outlet piping is not that hard. That's a boost control problem, not a turbo problem.
    • Thank you all for the replys 🙂 I know that intake would be different but that is one pipe at it is not that hard to get(custom one). I meant mainly bolt to the stock manifold and the turbo elbow. I looked and many sites/forums but they are just "old" with some old HKS turbos from GT-R i guess? What about some Garrets?  Or any other turbo? Is there even a turbo which i can just bolt on? 😄 And yeah i know about that new HKS but that is like 2000k USD without taxes/shipping in here   Iam getting a touch up tune but my "problem" is that on the "not" hot day iam getting peaks around 0,9 bar...and when it was around 15 Celsious i saw peak around 1 bar which is just too much for stock turbo. And of course turbo is old and i like to get some new one for a piece of mind 🙂
    • I'm working on the assumption that our friend Jasmine here is a Russian (or, possibly Ukrainian) spammer/spambot, based purely on the number of such that I have been having to neuter in the last few weeks. IP address for the OP above was in WA. But that could have been via VPN. Posting at quarter to 4 in the morning is a good sign of being from somewhere in Europe. The last Jasmine that I kicked in the cooch was IP addressed in Ukraine. Even that could have been via VPN, and the bitchbot could have been from Russia, Serbia, China or anywhere. Regardless, was a spambot, so I killed it with fire. The fact that our new friend Jasmine here did not respond in any way to my tart query strongly suggests to me that this OP was just the establishment phase of a user able to be activated for spamming in a week, or 3 or 10.
