Received my kit yesterday, and fitted it up this morning, took a couple of hours to do from start to finish including removing old standard unit.
Everything bolted up perfectly and lines up spot on, great quality and an excellent upgrade for the electrical system ready for any added extras down the road.
Personally I found the best course of action for fitment is to drop the old unit off through the gap between the radiator shroud and the power steering lines etc, and have the extension bracket mounted to unit not fully tightened, that way you can wriggle stuff around when lifting the new one up through the gap, hardest bit, and part that illicits the most cursing of engineering design etc. Is the placement of the lower pivot bolt, you can either see it, or you can get a hand in there to fit it, Never both! Once bottom bolt is in the rest is easy as.
Electrical system is now a lot more stable and also a bit quieter on the belt noise level with the new pulley too, so I will be recommending this kit to all of the local jdm nut bags and passing them the info/links etc.
  • Like 2
Yep, 100% agree, ive only recently got my car back from the workshop so haven’t done a heap of driving but I’ve already noticed the electrical system is better, before with lights on and stereo on I would see a drop in voltage and that was only running one fuel pump. I’m now running three pumps, no issues, no volt drop.
Very happy customer here.
But I didn’t fit it, I had the workshop fit it.
  • Like 1
3 fuel pumps? jeebus I'd hate to have your bloody fuel bill hahahaha, 2 questions... why 3 pumps? and secondly are any of them a "drop-in" upgrade that aren't as loud as a rotary13B sitting in your boot?
I might look at doing a pump and reg upgrade in the future but don't want a massively loud thing resonating in the wagon, so I'm looking for recommendations of an in-tank minimal fuss type of thing, any suggestions?
Fuel system was done by DVS Tuning, radium surge tank with twin walbro 460’s staged and another walbro in the main tank feeding the surge tank.
It’s unbelievably quiet, I’m very happy with it. Supports my 500kw and is good for substantially more should I wish to pursue more power in the future.
This is why I upgraded the alternator
  • Like 1
22 hours ago, cul8er said:
Anyone have to do a power cable to support the extra 70a due to bigger alternator ?
mine already had much thicker cable than standard due to the car having a uber-ridiculous stereo system in it when i got it, but can buy 200amp rated cable  10mm thick in super cheap which is about $8-10 a metre that'll be more than up to the task, then go to an electrical wholesaler or battery shop for the crimp on ends
Just fitted a rat32r kit with an alternator he supplied. Very nice kit and straight forward instalation. Idle voltage has gone from 14.2v to 14.45v. The Attessa light is staying off now, so the only remaining issue is the ABS.
  • Like 2
  • 1 month later...
Do you know how i can get hold of rat32r i have messaged him on here with no response
Would it be possible to see a pic of an RB spec Mitsubishi Alternator next to the LS Mitsy one please .
I'm very interested in this kit but just curious to see if the LS one is larger in diameter compared to the Nissan supplied one .
Mine would be for an R33 spec RB25DET .
Thanks in advance , cheers Adrian .
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
