I mean, I think half the reason  they sound so good is  because they are not using traditional  merge collectors. The original gtsr unit has a flat style collector, the reproductions shown in this thread have angle-cut pipes, but the collection is still "flat".
Could  one not just use two 3-1 flat collectors and the exact same pipe lengths as the original item?
Then again,  I can't fabricate so I could be missing something obvious here.
Whilst i would absolutely love a genuine R31house item i would never support speedtek in any way shape or form, even if i was receiving a free manifold from them. f**k speedtek.
  • 3 weeks later...
The speedtek manifolds don't even come close to the quality of the R31house equal length, single piece, hand bend runners.....
They're no where near equal length either.
I've spend literally hundreds of hours searching and attempting to translate any info over the years on gts-r manifolds and especially the R31house manifolds and his journey to recreate "that sound" and from what I have found, there's been three iterations all up now.
The first was the long large diameter merge type:
The second iteration is the one I have called "max" :
And the latest version 3 is the "premium" which just launched a few months ago, here's a pic of one with an original gts-r:
I managed to translate a blog post from R31house from a few months ago stating that the particular sound that R31house refer to as "that sound" comes from the pressed plate steel merge collector on the original Hr31 gts-r manifold and they've only now with modern tech been able to 100% recreate the original and finally achieve the 20 year long goal.
Another interesting translation was that he said he felt his car lost response and power with the v3 "premium" compared to the v2 "max" because the runners end at the start of the plate steel merge with the openings facing directly at the inner front flat face of the merge collector and this creates turbulence BUT is the precise cause of "that sound".
I also have seen two versions of the actual RB20det-R GTS-R manifolds as well, the normal 1-800 homologation Hr31 gts-r manifold with press bent like runners and heaps of splatter from the welds Etc.:
Then there's the Hr31's that the racing teams like Reebok, Calsonic and Gibson etc. received and the manifolds they had was the same design with much, much higher quality materials, runner bending and welding...
The ReeBok car:
I even tracked one down 5-6 years ago on a sale thread and contacted the guy selling it and it turned out he was an actual mechanic for Gibson Motorsport and the manifold he had (sold) was unused because when they received the hr31 race cars, Gibson removed the manifolds immediately in place for the custom Aussie made Gibson manifolds, this is that actual for sale thread photograph:
And obviously this is the Gibson manifold:
*all photos taken from google
  • Like 3
I genuinely love these manifolds and live to share the information to those who also have a genuine interest (:
And I have actually left out a couple of others hahah...
The Hr31 Autech had shorter runners and a smaller merge collector into a t28 flange which was widely rumoured to spool a lot faster and produce better numbers than the gts-r manifold even though it's wasn't equal length:
R31house has also done a couple of the Autech recreations in the "max" v2 style, note the unequal runners:
  • 2 months later...
Just had this arrive fresh from the motherland, a piece from the owner of R31house’s personal inventory..... A brand new completely unused GTS-R turbo manifold still with the original Nissan part number label on it ?
Feast your eyes.....
  • Like 1
  • 1 month later...
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
