2 minutes ago, sneakey pete said:
If you go a 3788 you'll have even more headroom... but then again a 4202 would be future proof :P
well.. if that's the case might as well drop in a LSX and run 2x of those turbos :)
Done!
Thanks for all of the replies.
I see the Hypergear stuff is strongly suggested.
i'm looking at this: http://www.hypergearturbos.com/index.php?route=product/product&product_id=57
ATR43 400~600HP T3x Internally gated turbocharger
Would I need to send my turbo in to Hypergear or is this a whole new turbo? (can i part-exchange my turbo? Else I got no use for it)
It is almost direct bolt on.  You will need oil and water lines.  Tao can supply those with the turbo, or you can look at eBay....but easier for you getting them from Tao.  The dump should match Nissan pattern.  The inlet needs modification.  You can't use the skinny rubber Nissan shit.  You need to fab up a steel or alloy 4" inlet that will also accept the AFM and your BOV return, etc.
you dont need water or oil lines with the 43 and 45 atr's. it just makes it a little easier to install with them.
There is a bit of custom involved, as gts said. But nothing serious or hard. And depends how neat you want it... Get some more pipe, a 90deg bend and some random silicone joiners and you should find a nice combo.
Get BB If you want better spool. I'm all in at around 3500 with journal with the atr43g3sat.
Install process:
FYI: You need around 60mm studs, not 40mm. Also there are easier ways to do the install than shown below.
I'm holding off on the turbo for now.
A buddy may be able to get me a NEO motor complete with turbos.
Would that just be a simple matter of removing the existing RB25DET and replacing it with the NEO? Is the wiring harness the same?
Luckily I wont be doing the work. Will send it to my buddy's shop but I will help so I can learn at the same time.
No, the wiring is not the same.  There are differences at various sensors.  The Neo has a boost sensor for the ECU that the vanilla 25 doesn't.  You need the R34 loom and the R34 ECU.
it will probably be easier for me to get an aftermarket ecu.
these cars are rare in south africa. especially the r34
if i do find one however I will get it
Edited by Die$eL
ok so my buddy just called.
He is able to get me a complete NEO motor with auto box, ecu and harness
would it then just be a matter of me replacing my engine, ecu and harness (not gearbox).
Is the ecu for the automatic cars "linked" to the gearbox in any way? Or would it just be a matter or fitting a resistor for the shift solenoid?
The R34 TCU is in the ECU.  And that's fine, because it doesn't matter - it will run a manual trans engine happily.  You're going manual right?  Because if you're not, punch yourself in the face and start again.
If you use the R34 ECU you WILL want to get Nistune installed in it, because you will want to kill the error codes caused by not having the right ABS and TCS systems installed in the car. And you WILL want to tune it.  All of which, happily, Nistune enables for you.
Assuming you go Nistune with the R34 auto ECU, which is the smartest option for what you want,  You can turn all the auto specific flags, so the ECU no longer looks for it, therefor you won't see any CEL codes.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
