On 22/04/2018 at 10:18 AM, Easto said:
Yes in all her beaten glory.... If it makes the second session I'll be surprised lol
If only Oran Park was still here. Miss seeing it out on North circuit
  • Like 1
How many spots are left?
My car might just be ready in time and I have 2 mates who are 100% in if I can make it. We all have cams licences, so its just a matter of me running my car in.
I spectated last year, and was a perfect event so would love to come.
We still have plenty of spots, we are at about the 1/2 way mark.
  • Like 1
Ok guys bit of a pickle, i have figured out what to do with the fire extinguisher but the tow hooks are the next thing for me. Rear is accessible but what to do at the front?
Total track newbie here.
I've seen a few people use a tow strap for the front. It looks like a seat belt type material.
On 4/18/2018 at 5:25 PM, G3TFKD said:
Thanks for following up.
Max would be 5.
I've got 3 definite and 2 tentatives
Any word on you and your mates signing up man? One member unfortunately cant make it now - we now have a paid spot to fill!
***ATTENTION ALL ENTRANTS***
If anyone else is going to register, but hasn't done so yet, get in contact with myself or @crashdown before you do - we have one non-member spot that needs to get traded, and can figure out an arrangement with either a member or non-member entry!
Yeh sorry mate. I've been getting smashed left, right and centre with a new baby and work.
I'm out for this one. Too much going on at the moment and my car is not ready to go.
My mates are indicating like they are dropping out as well.
    • Well, this is probably where a wiring diagram and a multimeter come into play.
    • I can say to anyone thats doing this; having done a number of R clusters; just be careful if its an unknown cluster.  It takes a bit of force to pull up; but if it feels excessive then its probably stuck. I've had this and pulled the entire hair spring out; and I can tell you; its not easy getting the correct spring replacement with the correct inner diameter and winding. In my case someone had used some sort of adhesive to stick it to the spindle and it pulled the whole spindle out; which the force seperated the hairspring from the spindal and caused it to deform.  You may have to clean it (IPA); or in my case if i'd known i should have used some sort of solvent on it.  Also check out Cruizin Central on eBay. He does all sorts of dials; and you can email him with any custom designs you want. So if you want like certain logos etc...he'll send you a mock of what it will look like then you accept the order and he'll take care of the rest. Fantastic dials and he can do basically any design you want.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia front end... *Edit: On closer inspection the test car still had the R32 body, but only the front end had Silvia panels etc.
