I have an R34GTT project that I brought many years ago.  Has original Rb25det engine and manual gearbox with HD clutch to go with it. Car had been modified and previous owner stripped aftermarket turbo and performance parts to sell car and never put back together. So engine needs stock injectors and turbo put back on (pretty sure I have all of this)  and engine and box put back into car.  Pretty sure almost everything is complete to reassemble, clean mostly complete interior car had 145,000km at the time it was taken off the road.  Needs front and rear bars painted(lower Altia kit) ,  has been stored for at least 6 years that I have owned.  Fully complied and clear title.  Being sold as Is where is.  Will be getting some pics in the next few days. From memory it had tanabe coil overs,  nismo sway bars and a few other bits and pieces that I would have forget about. Probably missing a few bits and bobs from being stored in pieces for so long.
Want $7K on Stockies or $8k with a set of genuine 19" volk CE28 19" gold rims
but open to offers.
 car is located in Deniliqun NSW 3hrs from Melbourne,  7.5hours from Sydney,  6hours from Adelaide.
Strictly pick up only, no delivery. Not interested in organising freight as parts are bulky.
Judging by recent 34 prices if someone is prepared to put in the work could end up with a nice cheap genuine turbo manual GTT
These will be the next generation of collectable car like the genuine mx7 plated vl Calais turbo
I don't come on here much but pm me I'll check it over the next few weeks
https://www.sau.com.au/forums/topic/473559-r34-gtt-coupe-rolling-shell-project/
  • 1 month later...
  • 3 months later...
  • 2 months later...
  • 1 year later...
  • 3 years later...
I think you'll find that the cost of this bare shell would have gone up considerably since then, so be mindful if anyone bumps this thread to not entertain the absolute steal that a 8K 34 GTT coupe shell would be (and was, back then)
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
