Hey guys,
I d like to ask for advice... My newly bought skyline running perfectly on 7 psi but if i raise the boost to 10 psi it cuts out at 6000 rpm and i just cannot tune it out.... when the engine is hot its getting worse (5500rpm)... I connected a  smoke machine to check for leaks...I marked the blocked pipes with red X....the smoke is immediately (at low pressure) coming out from the crankcase and from the inlet manifold...
It just doesn`t make sense to me how can it smokes from the engine when everything is blocked... Is my turbo leaking through the bearing housing back to exhaust and through the open valves comes out at the inlet? Or is it normal? Any idea? I m kind of getting hopeless for now maybe just i m the dumb and cannot tune it out (datalogit power fc, Z32 maf)... pls don`t spare me everything helps, have a good one
https://www.sau.com.au/forums/topic/473789-rb25det-turbo-leak/
Sorry about that i just didnt make a picture how the smoke was connected so i tried to improvise.... I connected the smoke to the inlet before the turbo (blue arrows).... I blocked the inlet from the intercooler so it should hold the pressure... but it s not holding any pressure since the smoke is coming out from the inlet manifold and the crankcase where the red arrows are with the ???.... And that s what i m asking if it s normal?
I assume you have the breather pipe and bov plumb back pipe blocked that comes out of your stock intake pipe. Try blocking it closer to the turbo, for example, block it before it enters the intercooler.
or, enter smoke right after the turbo and block off the same as your picture^^
NEO25T: I think I m gonna try it on the weekend
Kinkstaah: yeah it is an Apexi Power FC with Datalogit I have a log file what is happening...
the AFR at the cut point is about 10.75 (so it s not too rich or too lean) I ve tried to adjust the airflow data....change the whole MAF...still the same... after the car is hot the cut is happening at 4320 mV or less... It is a Garrett GT28 turbo, 7psi wastegate with a turbosmart tee set to 10psi
RB25detonator: yeah i ve done it too leaking out on the same places (crankcase and inlet)
Out of curiosity how did you block the pipes?
The easiest way i found was to bag the end of the pipe with black plastic and clamp it back together.
What spark plugs are in it, thinking back mine cut out like a rev limit at 6k when i got it. The plugs in it were nasty and new ones fixed it up
On 4/18/2018 at 8:50 PM, Ibanex said:
yeah I used rubber gloves with clamp for alloy inlet and for the hose used degreaser can and clamped it  for smaller pipes just bolt and clamp.
I thought about the plugs too and I changed them last week for NGK BCPR7ES... they should be fine right?
They should be OK but Iridiums better. If you still have stock coils are your plugs gapped down to ).8mm?
the only thing is that it really doesnt feel like a missfire...it just cuts out all together...  these plugs came already gapped to 0.8mm and the coilpacks (blue splitfires) should not be older than 2 years... so not too much left just keep on experimenting and spending some money...
If that is a full WOT pull, from the entirety of the video (i.e not backing off) and boost is dropping into massive vaccum like that, I'd be putting my money on that stock silicon hose sucking shut.
Especially given you said it runs fine on stock boost...
  • Like 1
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
    • OK, now we are ready to get started. You need to remove the air boxes on each side for clearance. The cover is straightforward, undo the clips on the top and lift the front cover out of the rest of the housing. If it is tight you can remove the air filters first. The rear section of the airbox is trickier. On each side you need to remove the Air flow meter wiring which is held to the airbox with a clip; you need to get behind the clip on 2 sides if you want to remove it without breaking it - unclip the harder side and pull on the clip with medium force, then unclip the easier side and it should pop out The airbox is held onto the intake hose with a spring clamp; you need to get a flat bladed screwdriver behind the spring on both sides and pop them outwards. When you have got them in the right unclipped place they will stay there and the airbox slips out pretty freely. Put a rag in the intake to prevent anything getting dropped in there, and also to prevent you seeing that the turbo seal is leaking oil (as they do). Then. The top of the radiator is held by a steel plate, it is secured by 2x10mm and 2x12mm headed bolts . Remove them and remove the plate Also grab the bushings that hold the radiator to the plate on each side so they are not lost!
    • Next, remove the upper and lower radiator hoses, both are held with a spring clamp. While you are under there, tackle the Auto Trans cooler lines.  Again both are held on with spring clamps, and as mentioned above you should cap them on the radiator side with an 8mm cap, and on the car side loop them with a length of 8mm pipe - this will stop you losing a dangerous amount of AT fluid during the rest of the job If you've been meaning to add a sender for AT trans temp, this is a great time to do it; put a sender fitting into the passenger side line as that is the inlet to the cooler/radiator.
    • Next you need to remove the intake duct (as with pretty much every job on these cars), it is a series of clips you gently remove with a flat bladed screwdriver. They do get brittle with time and can break, and I have not found a decent quality aftermarket one that fits (they are all too soft or flimsy and don't last either) but the nissan ones are a couple of bucks each (ouch).  Once the clips are off (either 8 or 10, I didn't check) you lift the intake duct out and will see the reservoirs Undo the line into the radiator side cap (some bent needle nosed piers are awesome for spring clamps) and then remove the 4x 10m nuts that hold both in place.  I didn't get these pics, but remove the line under the radiator reservoir (spring clamp again) then remove that reservoir. Then you can get at the intake reservoir, same thing, spring clamp underneath then remove it. BTW This is a great time to put in a larger (+70%) combined reservoir that AMS makes..... https://www.amsperformance.com/product/q50-q60-red-alpha-coolant-expansion-tank/ They also make an Infiniti branded and part# version if that is your thing
