39 minutes ago, Dose Pipe Sutututu said:
Didn't you mention your VCT is cooked? I would be focusing my energy on fixing that.
It still works but its become noisy so ive stopped driving it.
I emailed kelford and tighe cams, kelford just say that there cams wouldnt be any better but also say they can give stock like response whatever that means.. but i was expecting more depth and enthusiasm in the reply which is disappointing if they are experts in there field...
Tighe cams didnt respond at all... so after much reading of sau threads it would seem that lift is important but duration should be kept stock or to a 250deg..
Info on cams is a bit hit and miss really and i beleive there is a sweet spot to be found.. so my current thought is i will try a set of 250deg 9.15lift from japan cause i have little faith in companies that give short or no responses... japanese atleast are passionate about engines it seems...
So maybe ill be the ginnea pig and give a direct comparison of 252 vs 260 on an RB3025... as i think stock cams lack lift to get max area under curve...
Will also try advance a 252 intake..
Im out til is done.. cheers
52 minutes ago, Dose Pipe Sutututu said:
keep your Poncams, fix your VCT, get a twin scroll rear housing, twin scroll manifold and enjoy car
I had the twin scroll setup on RB25, it wasnt very impressive, alot of stuffing around and expense compared to a cam swap..
  • 3 weeks later...
I agree with this .
I think you need to consider what people have achieved with the standard Neo turbo cams . Its great to theorise about valve lift but that's only one part of the camshaft story .
252 Neo Poncams are still going to have too much overlap for an engine you want to make good part throttle power with IMO . If it were me , and I wanted your preferences and had coin to spend , I'd consider using slightly oversized valves to make it breathe better and be nice all round .
If you want to see things from a factory perspective you could look at 1JZ vs 2JZ turbo cams because its sort of similar deal to 25DET vs 30DET . I haven't done this but I'm pretty sure 2JZ turbo cams don't look anything like Neo T Poncams - even the 252 9.15 ones .
  • Like 1
Thanks for all the replies
The stock cams might be worth a go but then i lose lift so maybe weaken the         3.5-7K which is a fail...
So thinking if i can have the 260's ground back to like 244degrees or stock duration and would that make the ramp rate more aggressive..( i hear thats a good thing)
Tigh cams said they can reduce the duration but i dont know enough to understand how that affects overlap, ramp rates and what duration is the sweet spot..
Also, if duration is reduced too far eg 240, would i then have knock issues?
As i said from start, im only looking to improve response and shift curve to left, not lose any.
Edited by AngryRB
On 7/13/2018 at 6:37 PM, discopotato03 said:
I agree with this .
A few comparisons of other factory 3L factory cams but they have restrictive stock ex mani and lower comp probably.
2JZ has In 224 7.88 and Ex 233 8.4,
Z32 has In 248 8.5 Ex 248 8.5
Z33 has In 238 9.2 Ex 240 9.2
http://www.tomeiusa.com/_2003web-catalogue/e090_camshaft-specs.html
Neo cams are In 236 8.4 Ex 232 8.7 which are very close to RB26 cams, but neo has bit more lift.
The drop in duration from 240 in the r33 but extra lift is interesting as the compression was bumped up at same time.
I reckon the 260s are suited to 3500rpm onwards but at typical road conditions does rob response.  I noticed now that at 2k and accelerating out a corner im pretty sure its starting to surge.. makes a fluttering sound, that plus has always been hard to drive at a crawl or cruise as it jerks..
If this is reversion then the right duration will likely make a notable difference in response and drivability..
Be interesting to drive a 2JZ, they some low duration cams..
Look down.....on the left hand side of the drivers seat is a thing called a gear lever.....if you master how to use this then you can increase your street response without affecting top end power!!!
Seriously you are trying to split the atom....you already have a great motor and setup.  If that's not enough then try the std cams and reco'ed VCT like everyone suggests before selling any kidneys and buying stuff!!!
  • Like 1
  • Haha 4
    • Just a thought, how come you didn't use a 4D table? So you essentially run 2x fuel and 2x ignition tables, and the table/map switch is handled when there's enough WMI pressure detected. This is mine, but using the flex sensor as the 4th dimension, note the slider at the bottom. Between 0 to 70%, the timing is blended/interpolated , once it goes past 70% ethanol full send
    • Hi guys, after dreaming of owning a JDM legend for 20 years, I got the chance to buy a 1995 R33 GTR.  I live in a small country called the Solomon Islands which is in the pacific. There is no performance car scene here, however 90% of vehicles here are 2nd hand Japanese imports so there is a handful of JDM sports cars here, tucked away.  3 Evo VI’s, 1 180sx turbo, 2 GTO’s, 1 R32 GTR and 2 R33 GTR’s.    Only 1 Evo and a 33 (mine) are active. I’m hoping to set up a club to get these cars back in the road.    I’d known of my GTR for 9 years and always dreamed of owning it. At the start of this year I found it sitting outside a workshop waiting for a respray. It was in pretty bad shape, although running and driving perfectly apart from a big exhaust leak and worn out bushings. My brother in law who is a huge GTR guy came over for a holiday and I took him to see it, he got into my ear and I bought the car 2 weeks later as is.   I’ve had a pretty bad problem with alcohol and weed since 2020 and I really wanted to quit. So I used this as my motivation. I quit everything cold turkey and have been investing all my spare time into restoring this car. It’s honestly been the best experience and has been such a positive impact on my life.  There is no market for these cars here, no parts and no mechanics that can work on them, so if you wanted to sell one it would be pretty impossible unless you found the right buyer. After a bit of negotiating with the previous owner (a good friend) I got the car for $15,000 AUD ($85,000 SBD) which is insane.  I’ve almost finished doing a refresh on the engine, new turbos, spark plugs and split fire coil packs. Also new gaskets and seals, This car had no leaks to begin with, but it’s due now being 30 years old. . Next I’ll be working on the suspension, all new bushings, ball joints, king pins and new coil overs.  Then it will be body work, it has really bad rust in the boot floor, I have purchased a rear beaver cut from my bro which will replace the rusted out one. The car is originally KL0, but was burnt orange when it landed here, then it was resprayed toxic green and then Bayside Blue. I’m probably going to get it redone in Bayside Blue.  I’m super grateful to be able to enjoy this car and couldn’t have done it without my bro Chris from OG-JDM. Looking forward to the future with this car and hoping to get it on the runway at the airport here 😂  cheers fellas
    • Also, it is just about triangularity. The less angle, the easier it physically is to do. Think of the amount of slip you're getting, as how hard you need to push an object. More slip, equals pushing way harder. Then the ramp is how steep the hill is. The Accel is less slip, which means it takes less pushing (less slip) to get it to be able to push apart. However, the steeper sides on the decell means it will take a lot more pushing (slip) to get it up the ramp.
    • It's the angle of the ramp from the vertical. You're measuring from the horizontal. To convert, take 90* minus your angle reference = Nismo Angle.
    • I agree, thus 45 degree is the *max* force one could apply to it. This is similar to what I've seen in uh... simulations... which allow you to play with diff ramp angles. Anything higher (or lower) than 45 degree would produce less force as 45 is the max... triangley.  I would state the 1 way is 90 degree, at least this is how my brain and other ways of explaining it refer to it. 90 degree also effectively acted completely open. I realise Nismo refer to it not as 90 (or 89) but "1". So I'm not understanding the angle on which these angles are based.
