any idea on how to do a burnout in a 300 rx stagea? it doesnt have traction control or anything but every time i try all the engine does is rev to 2000rpm and nothing else, i hold the brakes just enough to stop the car rolling and try to rev the engine but nothing, what am i doing wrong, i can try chaining it to a pole but id rather not atm
https://www.sau.com.au/forums/topic/474324-stagea-m35-burnout/
On 6/21/2018 at 11:25 PM, Ben C34 said:
Hahahjaja even a v6 commodore can do a burnout! Hahahhaa
put an ecotec in it mang
^Truth. I took mine to the wrecker a couple of weeks ago and engaged in some private road testing along the way. Smoking a 235/40R18 was ridiculously easy, even with 305,000km of abuse on the clock. Instantly regretted getting rid of it. :(
PS: My new Leaf loses traction if I nail it from a standstill. What am I doing wrong? Not enough shopping bags in the boot?
Just checking, but you all know about the throttle cut out from the ECU with brakes on right?  NM35 all have that problem due to ECU having a throttle restriction when brakes are on and I think for about 3 seconds after brake release. I would assume PM35 is the same?  Solution is the brake wire cut/switch mod (look for it on forums).  I did mine - very easy to do.  Better option is to get a re-flach of the ECU - some on ebay for NM35 - Nm35 stagea vq25det stage 1 ecu reflash its-rom
awesome ill give that a go cheers
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
