Becareful not to drill too far in with the head drain, because you'll essentially need to remove the head to clean up the swarf you've dropped into the motor lol.
I didn't bother with one (wish me luck).
I installed some BS harden engine mounts by vibrant or some bs.. the car vibrates a bit and I hate it.
  • Like 1
5 hours ago, iruvyouskyrine said:
Head drain is a band aid. Proper catch can setup is a solution.
Engine is out. Easy to do head drain. Should be doing both especially if you are going to turn it up.
I'm using nismo engine mounts. Look exactly the same as the stock ones. Probably can't tell when driving but it definitely vibrates nuts loose. Use blue loctite on whatever you can.
  • Like 1
The swarf is one of the main reasons why I have not put this to top priority.
This is what I thought, But how much oil are we talking about here.
What I would straight out like to know is just how much oil are we talking here getting pooled in the head, Especially after restrictions etc on a neo motor.
front 1.0mm block rear will solve 80% of the problem, the other 20% is a catch can that relieves crankcase pressure and lets oil return to the sump through the oil drains as the system was designed
  • Like 2
  • 4 weeks later...
Decided to not go down the path of a head drain, I figure a good catch can setup along with the restrictors that were fitted should do the job. Once I have the motor in and I can see how much oil and its condition I'll see if it's worth returning it back to the sump.
Dropped the gearbox to get ready for push/pull conversion. I won't lie in saying that I am a little hesitant to do it entirely myself as I have never actually had to use a die and tap before. The last thing I want is old butter fingers here to drill into my bell housing cock-eyed the punch thread that I am certain; Will somehow catch fire homer style. So jus' wait in for mate.
Change the fuel rail back to the raceworks one as the return is better suited for dual feed. Waiting for a belt set to come in the mail next week and motor is ready to go. Par this chip on the HB which I am deciding to replace or not...
Also took the time to throw the interior bit in, Gauges, Cluster and seat. Only the drivers as these stradia XL copies don't fold all the way in. 10 years ago I wouldn't have cared and gutted the rear, But now I want to be able to share the experience with the kids from time to time. Key's racing wheel (Feels great, But the build quality feels poor. The alignment of the stitch isn't center and that irks me a little for a wheel I paid near $500 for, But I guess I have to live with it as I believe these are still hand made)
But the office now feels great and a lot more "personal" rather than generic GTT.
I'm thinking of maybe just going a sparco fixed back...
Edited by Vodkashotx
Ahh, i understand. I'm in the process of replacing a blown box in my r33. I couldn't get a new 33 box as they've been discontinued but i was able to get a brand new r34 box which im going to convert from pull to push by changing the front cover/bell housing from my 33 box over. That way I don't have to drill anything or buy any additional parts.
  • 3 weeks later...
Got the push pull done finally. Cbf'd taking pics.. It's the same ol box with a different front housing and slave.
Now setting up fuel system before I put the motor back in, Just wondering; Is running braided PTFE under the vehicle ok? It would make my life a million times easier than making up steel lines and feeding them through the impossible gaps (most likely drop the tank...)
I ran mine under the car where the standard lines were, just had to open up the plastic clips that held the old lines. I ran -8 feed -6 return, no surge tank in mine i just ran 2 walbro pumps in tank
  • 4 weeks later...
Hey guys,
Wondering if anyone could give me some assistance;
Ripped out the Hicas computer as I want to place the surge tank and pumps in the rear shelf. I have a lock out bar on the hicas system. (Yes, I'm gonna get an eliminator kit. Just want to get the motor in the car first)
Is the safe to do?
You need it, if not your steering wheel will be heavy as fk! The hicas computer also calculates the steering assistance required based on wheel speed and steering angle.
I noticed more of a difference to steering adding wide r comps than I did removing the hicas computer which was at least 3 years ago. I obviously  wouldn't be concerned personally lol ?
Chuck HICAS computer.
But drive it first and see if you can cope with the steering, which may take a while seeing you still got to find the motor mount bracket.
  • Like 1
On 5/7/2019 at 4:08 PM, Vodkashotx said:
Do I need to put the HICAS and ABS computers back?
(Which one is which?!)
In a R33, ABS is the smaller one.
  • Like 1
    • Just a thought, how come you didn't use a 4D table? So you essentially run 2x fuel and 2x ignition tables, and the table/map switch is handled when there's enough WMI pressure detected. This is mine, but using the flex sensor as the 4th dimension, note the slider at the bottom. Between 0 to 70%, the timing is blended/interpolated , once it goes past 70% ethanol full send
    • Hi guys, after dreaming of owning a JDM legend for 20 years, I got the chance to buy a 1995 R33 GTR.  I live in a small country called the Solomon Islands which is in the pacific. There is no performance car scene here, however 90% of vehicles here are 2nd hand Japanese imports so there is a handful of JDM sports cars here, tucked away.  3 Evo VI’s, 1 180sx turbo, 2 GTO’s, 1 R32 GTR and 2 R33 GTR’s.    Only 1 Evo and a 33 (mine) are active. I’m hoping to set up a club to get these cars back in the road.    I’d known of my GTR for 9 years and always dreamed of owning it. At the start of this year I found it sitting outside a workshop waiting for a respray. It was in pretty bad shape, although running and driving perfectly apart from a big exhaust leak and worn out bushings. My brother in law who is a huge GTR guy came over for a holiday and I took him to see it, he got into my ear and I bought the car 2 weeks later as is.   I’ve had a pretty bad problem with alcohol and weed since 2020 and I really wanted to quit. So I used this as my motivation. I quit everything cold turkey and have been investing all my spare time into restoring this car. It’s honestly been the best experience and has been such a positive impact on my life.  There is no market for these cars here, no parts and no mechanics that can work on them, so if you wanted to sell one it would be pretty impossible unless you found the right buyer. After a bit of negotiating with the previous owner (a good friend) I got the car for $15,000 AUD ($85,000 SBD) which is insane.  I’ve almost finished doing a refresh on the engine, new turbos, spark plugs and split fire coil packs. Also new gaskets and seals, This car had no leaks to begin with, but it’s due now being 30 years old. . Next I’ll be working on the suspension, all new bushings, ball joints, king pins and new coil overs.  Then it will be body work, it has really bad rust in the boot floor, I have purchased a rear beaver cut from my bro which will replace the rusted out one. The car is originally KL0, but was burnt orange when it landed here, then it was resprayed toxic green and then Bayside Blue. I’m probably going to get it redone in Bayside Blue.  I’m super grateful to be able to enjoy this car and couldn’t have done it without my bro Chris from OG-JDM. Looking forward to the future with this car and hoping to get it on the runway at the airport here 😂  cheers fellas
    • Also, it is just about triangularity. The less angle, the easier it physically is to do. Think of the amount of slip you're getting, as how hard you need to push an object. More slip, equals pushing way harder. Then the ramp is how steep the hill is. The Accel is less slip, which means it takes less pushing (less slip) to get it to be able to push apart. However, the steeper sides on the decell means it will take a lot more pushing (slip) to get it up the ramp.
    • It's the angle of the ramp from the vertical. You're measuring from the horizontal. To convert, take 90* minus your angle reference = Nismo Angle.
    • I agree, thus 45 degree is the *max* force one could apply to it. This is similar to what I've seen in uh... simulations... which allow you to play with diff ramp angles. Anything higher (or lower) than 45 degree would produce less force as 45 is the max... triangley.  I would state the 1 way is 90 degree, at least this is how my brain and other ways of explaining it refer to it. 90 degree also effectively acted completely open. I realise Nismo refer to it not as 90 (or 89) but "1". So I'm not understanding the angle on which these angles are based.
