Hey guys,
I thinking of installing an electric start button in my R34 GTR and was wondering if anyone has successfully done this or know where I can get it done?
MCM did a video on something similar a while ago but I want to go completely keyless and make it look flush and professionally installed:
Edited by Robocop2310
OK guys, I think you all made valid points so this only backs up my own personally feeling about use of a key in a Skyline.
I just wanted to see what you guys thought. Yep, not a good idea.
16 hours ago, Robocop2310 said:
Hey guys,
Which is your personal opinion?
Post 1 or post 7, or have they changed?
  • Haha 2
Or post 7, or post 1?
Push button start is cool.
Proximity keys are cool.
I kinda agree with all of you guys. Just wanted to see if it can be done nicely but looks like it won't so would only be wanky so it's a no from me too.
Gay.
What's the point when you don't have proximity remotes and you still need to use the key to unlock shit before hitting the button.
If you want that start button, delete the ignition barrel and have your ACC triggered by your alarm's unlock command. Then run a rocker switch of some sort for ignition then have a start button.
Or buy a Tiguan, chops stock GT-Rs ?
I have one in my 32 GTR from the prev owner.... its the dumest thing really. you need to turn the key then push the button.... if it was going to be anything it needs to be totally keyless or its a shit gimmick.
  • Like 1
A lot of these reasons for not going push button start are kind of redundant considering you can get a kit that includes proximity key arm/disarm, push button start, remote start etc.
I say do it and report back!
https://www.amazon.com/EasyGO-AM-UNIVERSAL-R-Universal-Proximity-Security/dp/B00HSF5EIS
I see...so it defeats the purpose anyways.
Thanks for sharing though!
I've since decided it's a definitely no. Just took my R34 GTR for a drive to the shops and would feel guilty for butchering it to install this electric start button. lol
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
