2 hours ago, niZmO_Man said:
Yeah, how shit were the halogen bulbs?
Headlights themselves makes a big difference. E.g. dad's Camry (last of the Australian made ones) has shit projectors in them. Upgraded H11 to H9, marginal. Threw in a "good" LED bulb, looks great/bright up close, is meh while driving (so if you're after just colour upgrade and output is same as standard, I can suggest a H11 for your projectors). Can't believe we didn't get the good Koito H11 projectors here.
Oh and that "group buy", the guy wanted me to transfer money to him directly instead of going through alibaba, no deal.
But yes looking forward to the output photos, I would love to be proven wrong but I haven't seen one single LED bulb that's an actual upgrade here in Australia.
I have the Narva high intensity high beams in the cruiser, the cheap ass low beam LEDs from eBay I had in it threw light as far down the road as my high beams, the only thing the high beams did was light the tops of trees up. And I'm talking the top of the tree, not halfway up the gum, just the top. The LEDs also lit the middle of the tree up.
Only way to get more light was to flick the light bar on. Unfortunately it's more of a flood than a spot bar. Still got more distance and width, but not like I would if I ran the bar I put on the old boys Hilux.
The current Phillips low beam halogens I have are rubbish.
8 hours ago, niZmO_Man said:
What bulb socket/fitting? Also which car/housing?
FYI Narva are rebranded Osram @ double the price
In the 105 Cruiser, HB3  and HB4. Can't remember which is which ha ha
Probably HB3, as most Japanese cars are. There's a nice upgrade for those high beam, 9011. I got a bunch of Toyota HIR1 (9011) that doesn't need any modifying, goes straight in with HB3 plug. It appears on our Tarago (JDM ones use HB3).
HB3 = 1860 lm
HIR1 = 2350 lm
It's the reason why the old Osram Rallye H7 was good, it had a H9 (2100 lm) burner (H7 is 1500 lm).
HB3 = 1860 lm
HIR1 = 2350 lm
Yeah it runs a HB3, and a HB4, I just don't remember which one is high/low beam.
I'm assuming from the above HB3 is likely my high beam?
Yeah I'd assume so. But still, 90's headlights man, not working with much. LED can help IF the emitters are positioned in a way to focus off the reflectors, which basically means custom made bulb for your headlight (unless it's a fluke, impossible to happen).
Reason why Diode Dynamics in USA made LED bulbs for F150. They happen to work quite well in other headlights.
  • 1 month later...
  • 3 months later...
  • 2 years later...
On 7/7/2022 at 7:59 PM, Wirelessstiv said:
One of the important criteria for selecting LED lamps for a car is the specific base of the car. In this case, the base is designated similarly to standard halogen lamps.
This time I'm quoting the post I reported, so I can say "f**koff" to it.
Ban. Ban Ban. Bananannannanana ban ban.
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
