Hey guys,
Iv had my 1998 nissan skyline for about 2 months now and iv been trying to figure out why its running so rich
Im getting 200ks A TANK!!!!. It blows black smoke and smells like fuel
Iv changed the o2 sensor, spark plugs, maf sensor
When the car is off and  the engine is warm the car stuggles to turn back on... it turns on but then i have to tap the accelerator to keep it on
When im driving and coming to a stop i clutch in and slow down and the rpms drop below 1000 and sometimes even stalls
When im speeding up and boost starts to build the car starts stuttering sounds like antilag tbh and i loose power
I dont know what it can be and would appreciate any help
Thank you
6 minutes ago, in71ce said:
I had the same problem with my GTR and found it was the fuel pump control module in the boot was starting to die
Um, how would the fuel pump control module make a car run rich ? All the GTR pump module does is put 6v, 9v or 12v to pump via dropping resistors within the unit, controlling how hard the pump runs. It could cause a lean condition, not a rich, as pump is not supplying enough fuel at load.
Im just stating what i have experienced
And how did you find that out ? If module fails and pump runs flat out at 12v, injectors still deliver the same fuel as programmed. Like wiring a pump to run flat out all of the time, which a lot of people do, won't make any difference to injected fuel to make it run richer.
If the module fails so it makes the pump run not at 100% at say 9v, at WOT, then the car will lean out under load. That's like saying a failing pump can make a car run richer.
At no time can the fuel pump control module fail in any way to all of a sudden make the car run rich.
For OP I'm leaning towards a big vacuum leak too as @GTSBoy stated above.
21 hours ago, GTSBoy said:
Nah, running filthy rich and not wanting to idle suggest a big fat hole somewhere. Dirty injectors usually lead to lean pops and only a moderate increase in fuel consumption.
Will pull the injectors out to get them cleaned and i couldnt find any vacuum leaks anywhere
Car idles fine just doesnt when the car is warm and iv clutched in while driving ....only last a couple seconds then will either stall or bounce back up and steady itself..
Have you pressure tested the inlet from the turbo to the TB? Boost leak is not always going to show up as a vacuum leak.
And, for idle control, how sure are you that the IACV is working properly? Cleaned it lately? Your symptoms (rolling stall) are typical of a sticky IACV.
my vote is boost leak, and yo umust pressure test. thats a rule. you cant see them.
second vote is for coolant temp sensor.
both votes hold equal weight and if i am correct you owe me a favor. talk later.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
