Hello!
Nothing is wrong with my car, all gauges read correctly, the car fees responsive, and it overall is functional and great.
However, with the cold temperatures, I noticed there is smoke coming out of my hood (the hood is vented) but I thought it must’ve been my valve cover filters that are venting to the atmosphere. I checked and to my surprise I found a whole substance on the exhaust manifold and turbo flange. I’m guessing it might be a leak? What do you guys think?
Im going to take a guess that hose is leaking. Id be rerouting that quickly. I have found out the hard way what happens when braided line touches red hot manifold before, not pretty.
Does the white substance wipe away or is it hard and crusty? (Could be someone has used exhaust putty on that flange).
My third theory is it's cocaine, you could try snorting it and reporting back.
Hello, I’ll reroute it to make sure. The coolant line doesn’t tough the exhaust manifold.
The white substance does wipe away, some of it is harder to wipe (kind of crusty) but it does wipe away.
I snorted it as well and it didn’t fee like the usual cocaine... hah
14 hours ago, Ben C34 said:
Dude, you can't have stuff touching the exhaust manifold.
You realise inside that stainless braid is plastic?
That is just crazy
Yes, I understand. I’ll make sure to change that!
  • 4 weeks later...
10 hours ago, kowalatea said:
I second this course of action
Not only did I snot this once, by twice just to make sure :)
i replaced and rerouted the line. It was leaking on the hot exhaust manifold and the exhaust manifold was installed with putty.
It is all good now!
Thanks!
This is mad mad mad crazy! thats how coolant looks when its cooked. you can NEVER have anything touch your exhaust manifold, fix that shit ASAP. that line is more than likely fu*ked and i suggest buying a new line...
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
