Hi all,
Wondering what to go for. Currently at 580bhp on 95 octane.  2860-5s with tomei type b cams.
Im looking get just over the 600 mark and extract more response.
options are the following
V-Cam step 2,
Pros : Definitly more response, more power across the entire rev range
Cons : Reliability ? still using outdated turbos. Not sure if my wossner pistons will work with it.
BG EFR 8374,
Pros : will see more power, less clutter and heat soak in engine bay. can sell current setup to reduce costs
Cons: possibly spending 3k for 300rpm or so spool difference
Vcam wise i cant seem to find any videos of an R32 with it, yes there are many dyno graphs but that doesnt translate to 2nd/3rd gear pulls and street driving etc.
Single turbo also sounds alot better, and you get the glorious SUTUTUTUTU noises which you dont get with twins.
Any advice ?
its a street car with some track use.
https://www.sau.com.au/forums/topic/479885-v-cam-or-single-turbo-conversion/
? 95 octane ? If so this is quite good.
Have you first considered going to a higher octane fuel, a re-tune( you didn't state your computer management system ) with more boost ?
May well get what you seek without a large out lay.
If it dose not work then up grade
VCAM should be pretty reliable, it's literally just the Subaru EJ25 AVCS bits with some fittings to get it on an RB intake cam.
If your pistons have valve relief for high lift cams then they should work with 50 degree advance. Don't buy the hype from HKS, you can fit either your own cams to the VCAM system with some modification or regrind the cams to get the desired profile. If you want to save some coin in return for some labor you can buy the step 1 system, pop off the metal block that they use to keep it within 30 degrees of cam advance and regrind the cam to your desired spec. Or replace entirely.
Here are some dyno charts for VCAM:
Step 1 VCAM with -5s vs stock with catback, no VCAM:
Blue is Garrett 3582 with step 2 VCAM, Orange is stock with catback:
More dyno charts here: https://www.facebook.com/upgarage/photos/?tab=album&album_id=2754286177933791
As for whether you should pick VCAM or single, I would say both? But it's big money to do that. If you want to know what the benefit at the top-end will be, get an adjustable intake cam and fiddle with the timing and see what timing gets you the best top-end. That will be your peak power. Fiddle with it again for best low-end response. Do that for every RPM and load combination and you end up with what a VCAM can do for you.
Having done this exact conversion myself, 8374/1.05 all day.
A dyno sheet only shows show much, actually, throw the bloody thing in the bin.
8374 to -5’s is much more than 300 rpm difference, more like 500-700 rpm not to mention the zing under the foot once you put the twin butt plugs in the dumpster where they belong. Transient response difference between the two setups are night and day... ALMOST 1/3rd the time, the winner going to the 8374. This was shown by logs off a mates car who also went between these two exact setups on a 3.0. Thats something that is not shown on a dyno sheet with a WOT loaded run.
Having also been in two different cars (2.6/baby vcam/-5’s and 2.6/baby vcam/8374), the 8374 would destroy it EVERYWHERE.
Sorry I meant to say 97 octane here in N.Ireland
If i was looking at a BW it would be the .92 IWG option, with the turbosmart actuator upgrade. From what ive read it tends to have better response and the turbosmart unit helps with the top end.
Ive seen those dynos before UpGarage I think ?
As i say my main goal is response and driveability.
Surely the turbo cant provide the same low/mid as a turbo ?
Think I’m gonna go with the single, even for the fact I can sell my current setup so itl be more cost effective. Just wondering what it would be worth ?
2860-5s with HKS actuators, 7k Miles with Braided oil and water lines
HKS elbows
Reimax equal length downpipes
Ported OE manifolds
HKS intake kit ( not sure on these they’re in good condition but they’re very pricey new https://www.rhdjapan.com/hks-piping-kit-special-type-bnr32.html
Has anyone used the .92 8374 ? I know it’s been covered but I’m more interested in drivability than dyno numbers
Just in terms of the usual drug induced thinking around twin turbos on GTRs around here, I'd suggest it would be worth about 120% of what it costs you to convert to single. Won't even have time to stand up after pushing the post button your for sale ad and it will be sold.
Definitely try GTRCanada/GTRUSA on Facebook, list with a 25-33% discount off new and someone will probably bite.
Forget the 0.92, go the 1.05.
Below is a back to back on a 2.7. Blue is 8374/1.05 and red is -5’s. Only change was associated pipework to make the single work.
  • Like 2
    • Hi, is the HKS  Tower Bar still available ? negotiable ? 🤔
    • From there, it is really just test and assemble. Plug the adapter cables from the unit into the back of the screen, then the other side to the car harness. Don't forget all the other plugs too! Run the cables behind the unit and screw it back into place (4 screws) and you should now have 3 cables to run from the top screen to the android unit. I ran them along the DS of the other AV units in the gap between their backets and the console, and used some corrugated tubing on the sharp edges of the bracket so the wires were safe. Plug the centre console and lower screen in temporarily and turn the car to ACC, the AV should fire up as normal. Hold the back button for 3 sec and Android should appear on the top screen. You need to set the input to Aux for audio (more on that later). I put the unit under the AC duct in the centre console, with the wifi antenna on top of the AC duct near the shifter, the bluetooth antenna on the AC duct under the centre console The GPS unit on top of the DS to AC duct; they all seem to work OK there are are out of the way. Neat cable routing is a pain. For the drive recorder I mounted it near the rear view mirror and run the cable in the headlining, across the a pillar and then down the inside of the a pillar seal to the DS lower dash. From there it goes across and to one USB input for the unit. The second USB input is attached to the ECUtec OBD dongle and the 3rd goes to the USB bulkhead connected I added in the centre console. This is how the centre console looks "tidied" up Note I didn't install the provided speaker, didn't use the 2.5mm IPod in line or the piggyback loom for the Ipod or change any DIP switches; they seem to only be required if you need to use the Ipod input rather than the AUX input. That's it, install done, I'll follow up with a separate post on how the unit works, but in summary it retains all factory functions and inputs (so I still use my phone to the car for calls), reverse still works like factory etc.
    • Place the new daughterboard in the case and mount it using the 3 small black rivets provided, and reconnect the 3 factory ribbon cables to the new board Then, use the 3 piggyback cables from the daughterboard into the factory board on top (there are stand offs in the case to keep them apart. and remember to reconnect the antenna and rear cover fan wires. 1 screw to hold the motherboard in place. Before closing the case, make a hole in the sticker covering a hole in the case and run the cable for the android unit into the plug there. The video forgot this step, so did I, so will you probably. Then redo the 4 screws on back, 2 each top and bottom, 3 each side and put the 2 brackets back on.....all ready to go and not that tricky really.
    • Onto the android unit. You need to remove the top screen because there is a daughterboard to put inside the case. Each side vent pops out from clips; start at the bottom and carefully remove upwards (use a trim remover tool to avoid breaking anything). Then the lower screen and controls come out, 4 screws, a couple of clips (including 3 flimsy ones at the top) and 3 plugs on the rear. Then the upper screen, 4 screws and a bunch of plugs and she is out. From there, remove the mounting brackets (2 screws each), 4 screws on the rear, 2 screws top and bottom and 3 screws holding in the small plates on each side. When you remove the back cover (tight fit), watch out for the power cable for the fan, I removed it so I could put the back aside. The mainboard is held in by 1 screw in the middle, 1 aerial at the top and 3 ribbon cables. If you've ever done any laptop stuff the ribbon cables are OK to work with, just pop up the retainer and they slide out. If you are not familiar just grab a 12 year old from an iphone factory, they will know how it works The case should now look like this:
    • Switching the console was tricky. First there were 6 screws to remove, and also the little adapter loom and its screws had to come out. Also don't forget to remove the 2 screws holding the central locking receiver. Then there are 4 clips on either side....these were very tight in this case and needed careful persuading with a long flat screw driver....some force required but not enough to break them...this was probably the fiddliest part of the whole job. In my case I needed both the wiring loom and the central locking receiver module to swap across to the new one. That was it for the console, so "assembly is the reverse of disassembly"
