yeah it is...the third largest connector is the one your looking at, remove it and measure for continuity between terminals 13,14,15,16,17,18,19,20 between .8 and 2.2, the terminals you are focusing on are in pattern. remember you are measuring the harness side not the atessa control unit side. if you have continuity between the connector terminals you need a new control unit. if you don't have continuity you need to measure resistance at terminals 1 2 3 and 4.  this will narrow it down for you without doing any wrenching at all.
@MoMnDadGTR
So this is my results
13 though to 20 is no continuity
So I tested 1 2 3 4
2 and 4 gives me 130
3 And 4 is contunious
2 and 3 gives me 115
I'm so confused how should the numbers be
You're not supposed to test all of them to all of them. The original linked document clearly says check 13-14, 15-16, 17-18, 19-20.
Expected resistance is between 800 - 2000 ohm.
You do not do this with the multimeter set to continuity. You do it with it set to the appropriate resistance range. Which will either be 2k or 20 k. Try 20k first, as raw accuracy is not important here.
If the circuit is open (infinite resistance) then you have a broken wire, dud sensor, something like that. If the resistance is drastically low, it's either a wiring short or a dud sensor.
You can see the difference between harness faults and sensor faults by measuring at the sensors, as shown in the diagnosis tree.
  • Like 1
@GTSBoy
I just want to clarify I have tested
13 to 14 15 to 16 and so on with my tester. There is no continuity.
So my next step would be to test the terminal 1 2 3 and 4. Can you confirm this is correct
There's not supposed to be "continuity" in the sense of a short circuit. The resistance across those pairs of wires is supposed to be between 800 and 2200 ohms. As measured with the multimeter set to the appropriate resistance scale, probably 20k ohms.
29 minutes ago, Semih_Ozdemir said:
The meter I've got is a fluke multimeter.
It hasn't got the setting to change over to 20k ohm etc.
This cannot be true. The very definition of a multimeter means that it can measure resistance. Fluke is the best brand out there. It is not possible that it doesn't have it.
The red arrow shows you the resistance mode. Flukes are autoranging, so you don't even need to select the 20k range yourself. It will do it for you.
correct the multi meter has to have the setting on it looks like a horse shoe. I also can add that when testing for resistance make dam sure you have a good connection in the terminal with a nice sharp end, sometimes you can tie a paper clip to the end of your multimeter probe to get a better connection in the terminal. this is sounding like bad ground, broken wire, something to do with the relocation I believe. let us know when you have done the resistance test on terminals 13-20. then we can narrow down if you need a new control unit or if we need to continue testing
ive always stayed away from relocations and what not to keep diagnostics easier and what not just keeping a simple fast platform. I do feel once the multimeter and you become friends your gunna solve this issue quick.
Okay @GTSBoy I've got a fluke clamp meter. My bad. It only measures continuity and not resistance eith a scale.
@MoMnDadGTR
I've got 2 sensors of a mate. I'm just going to replace the front right sensor and see if that fixes my issue
No. Swaptronics is the last resort, not the first.
A useful multimeter is $10 at Jaycar.
What model? I've never seen one that doesn't do resistance, current, volts, etc.
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
